Old 10-08-2015, 03:31 PM
70pontiaction 70pontiaction is offline
Smile I've had quite a few 'factory-equipped' Rally II cars over the years.....
And each one of them had a Rally II in the trunk, too. Usually, the cars that had been converted to mag wheels still had the Rally II in the trunk.
I've seen a few with Rally IIs and the standard steel spare - I presumed that the Rally IIs weren't factory and that whoever added them only paid for four wheels, leaving the original spare rim (and sometimes tire) in the trunk.
But that's just MY experience - your mileage may vary.....
Old 10-08-2015, 04:47 PM
SD455DJ SD455DJ is offline
Goodyear and Firestone were the most common OEM tire supplier, with Uniroyal and General tire supplying as well, for all styles RWL/WW/BW in G70x14 size in 1970.
Dennis
Old 10-08-2015, 06:38 PM
70oldgoat 70oldgoat is offline
I think these are repopped now, but haven't researched it. This was at the MCACN show last year. I have NO idea why the original owner (or dealer) chose to order a beautiful Diplomat Blue 1970 Buick GS Stage 1 convertible with a 4-speed and then opted for the wire hubcaps and double-white pinstripes, but that's the way the car was ordered. Most GS's had the stylish chrome Buick Road Wheels.
FYI.
I'm the original owner of a special order 1970 GTO. My car arrived from Arlington, TX, plant with poverty hubcaps, steel wheels, and G78-14 Goodrich duel narrow stripe WW tires. The spare tire, which I still have, is a same duel narrow stripe tire mounted on a steel wheel. The steel wheels, including the spare steel wheel, were factory painted the body color of the car, Atoll Blue.
The tires appear to be the same tires as the tires in the above Stage 1 convertible photo.
These tires can be purchased as repops from Coker Tire. I did not see them in their online catalog, but I called Coker company on the phone and they had them in stock as of a couple of weeks ago.
"Living our dream, shifting a 4 speed 1970 GTO down life's highway."
70 GTO HT, Original Owner, Atoll Blue, #s Match, 400, 4-Speed, A/C, Hot Rod Power Tour Long Hauler
70 GTO HT, Burgundy, Not #s Match, 455, 4-Speed, Hot Rod Power Tour Long Hauler
70 GTO Convertible, Granada Gold, #s Match, 400, 3-Speed MT, Floor Shift, Hot Rod Power Tour Long Hauler
Old 10-08-2015, 08:13 PM
Held for Ransom's Avatar
https://www.cokertire.com/g78-14-bf-...wall-tire.html
Old 10-10-2015, 01:08 AM
orejudge orejudge is offline
http://www.dbtires.com/ Called today and they will make a double pinstripe in any tire you want. My car came with g78 14 so going to order some radials in 225 70 14
Old 10-16-2015, 09:45 PM
SmallHurst SmallHurst is offline
Available from Kelsey for the Goodyear Polyglas in G70-14: Raised White Letter, Red Stripe, White Stripe, and now Blackwalls. Contact me if you have any questions about these tires!!!
Russell Small
1969 Hurst/Olds
13.26 @103.1
"Pure Stock is the way to Rock"
Old 04-05-2023, 10:08 AM
BurgundyJudge BurgundyJudge is offline
ID:	610228I just purchased a set of JL wheels from the original owner of a 70 GTO that switched the 14s out for 15s years ago. Included was this spare G78-14 Firestone which appears to be the original spare the GTO came with. I posted on the Pontiac GTO forum and a link to this thread was posted so I thought I would post this here if anyone is still interested.
Old 04-05-2023, 05:18 PM
That is one beautiful spare tire. What was the codes (numbers) of the wheels? What is the DOT number of the tire?
So long, farewell.
Old 04-05-2023, 05:50 PM
1965gp 1965gp is offline
If. Muons is interested in a set of thin white walls let me know. I had a set made for my 69 GTO and ended up going with white letter tires after I wrapped it.
Bought from diamondback tire a few months ago, maybe 150 miles on them.
Old 04-05-2023, 06:17 PM
goatboy1970 goatboy1970 is offline
Oooh, maybe. What size?
1970 GTO I Pepper Green, YS Code, numbers matching, PHS documented
Old 04-05-2023, 06:31 PM
The info on the tire is "DOT 147" and on the back 0027L256. I couldn't find any info on these codes. My car came with G70x14s so this tire doesn't work for me.
Old 04-06-2023, 04:14 PM
Yes. Unfortunately the codes have never been ID'ed. I was also asking about the format surrounding the valve stem, IE...M19 7 (valve stem) 25 JL. If you are selling, I may be interested as a conversation piece.
So long, farewell.
Old 04-08-2023, 01:30 PM
This is an interesting subject, my 70 Accessorizer is dated February 23rd 1970 and it shows that all GTO tires were G70. Apparently all standard tires on every 1970 GM car were fiberglass belted (in previous years fiberglass belts were extra charge. Also unlike previous years GTO's no longer had redlines as standard (with whitelines no charge option). In the accessorizer it states that the standard GTO tire was the PF blackwall, optional at extra cost was PR white line and PL white letter (white line option not available with Judge option). All three were G70 size. Looking at the 70 Hi perf brochure (dated 9-69) it lists the same standard tire (G70 black) and the same two optional G70 white line and white letter. The full line brochure (dated 9-69) GTO page isn't much use as it only has car illustrations and it shows a GTO convertible with red lines, a GTO hardtop with twin white and a Judge hardtop with white lines. The deluxe full line brochure also has illustrations but different cars with different tires: a GTO hardtop and convertible have redlines and the judge has black walls.
However, I have seen 70 GTO's with original spare G78 twin whites in junkyards.
Similarly some factory documents say the 67 GTO was supposed to have G70 tires as standard
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 04-08-2023, 06:08 PM
OG68 OG68 is offline
Wonder if it was a mid year change?
Eric White's identification guide calls out the G78 blackwall as the standard tire for the GTO with the G70s optional. Load range D, G78s were also optional with the trailer package.
2007 Cadillac SRX
Old 04-08-2023, 06:56 PM
Steve, the Sept. 18th 1969 '70 Accessorizer stated the std. for GTO was G78-14. The std. for The Judge was G70-14.
So long, farewell.
