got some manifolds, any good?
i got these and wonder if they are any good or how much they might be worth? i know clifford asks $1689.
Hard to say if they will make much of an improvement over the stock parts.
But they really are the only game in town for an aluminum manifold (assuming you don't have a vintage Man-a-Fre laying around). And the headers are the only ones that you might be able to buy right now. I am not sure why Clifford decided to use a Weber carburetor instead of a traditional square bore or Holley based unit. |
Sweet!
Someone spent some time on that engine, the headers may be worth more that the intake? Guessing it got pulled for a V8.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
The Following User Says Thank You to 694.1 For This Useful Post: | ||
IIRC the performance increase was marginal compared to the cost to get it all hooked up.
More Show than Go, but it does look cool.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
In my experience the the stock 4bbl manifold makes more power but weighs a lot more, the shorty headers are about a wash for true duels on the stock 4bbl exhaust manifold, the long tube headers made a a few more HP than the stock manifold with duels.
Unless you are going for underhood bling, or are trying to reduce weight the stock intake & exhaust make as good or better choices. Now if you are replacing 1bbl manifolds they are better choices, but you are still limited by the stock cam & valve springs on a 1bbl engine. As for value it is all over the place.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
The Following User Says Thank You to camerjeff For This Useful Post: | ||
thet are gone, ebay took them to the next guy
And for the most part, many of these Aftermarket bits have been exchanging hands for decades never really being used.
Someone will buy them with hopes and dreams to get them and use them only to realize there are so many other items needed to do so. I have quite a few file images showing Mock-ups but very few show complete and running. If I had a set, I too would likely just turn them into Wall-Hangers in the shop.
OHC-6 Weight reduction using AL Intake and any headers makes the OHC-6 lighter than the 455 (AL intake, headers).
Otherwise, part-for-part, the OHC-6 just might be surprisingly add-up as HEAVYier than the PMD 455 V8. Except the Rods and pistons. |
These are on a '68 Firebird. The owner has had the car for awhile, and no longer trusts the Sprint 6. Don't know the entire history, but they want the old motor swapped for a 428.
Not sure if they will be selling any of it, or keeping it.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
The shorty style were fab'ed up in Canada and the shipping costs alone were horrific. It would be sweet to have some made in this country.
I think they look cool out of the car but like a rat's nest, under the hood.
Clifford's first header was a real long tube design and a PITA to work with.
I had some pictures of a few sets that were lost after a system crash The 2nd design "SHORTIES" as they are referred to were more commonly seen but still in limited numbers. [/url]
A few off the engine images...
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 10-12-2023 at 05:55 AM. |
