Old 04-09-2023, 01:20 PM
Hotrodjohn71 Hotrodjohn71 is offline
Default Power brake boosters for 67
What were the size options for a power brake booster on a 67 Firebird?
Was there more than one option?
The booster on our car has an incredible amount of boost.
Old 04-09-2023, 07:37 PM
No, Just one size, 11" .
Bill Nye.
The Following User Says Thank You to TedRamAirII For This Useful Post:
Old 04-10-2023, 04:53 PM
That doesn't look like a factory booster. BTW, while all the factory boosters were one size that year the disc brake booster was different (different part number) than the booster for a drum brake car.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 04-10-2023, 05:35 PM
Thank you. I did neglect to mention that our car is all drum.
Thank you North. That is ab interesting bit of information. I wonder what the difference would be.
Old 04-15-2023, 11:01 PM
How much do you think I can lessen the boost by going to a smaller booster? Will there be a noticeable difference? I think mine is an 11". What about a 9" or less?
Old 04-16-2023, 07:22 AM
I am not an expert on this subject but I believe that boost level is related not to the size of the booster as much as internal orifice-restrictor sizing.
1969 Bonnie Cvt
Old 04-16-2023, 09:53 AM
Ok. Thank you. I have a new question after researching this for a while.
I see listed for a 1967 Pontiac Firebird (4) different brake boosters with seemingly no differentiation I can find (which really makes me wonder if my booster is correct for my application).
One is 11" single diaphragm, one 11" dual diaphragm, one is 9" single diaphragm, and one 9" dual diaphragm - all being listed for 67 firebird .
Old 04-16-2023, 11:15 AM
vertigto's Avatar
vertigto vertigto is offline
If you're looking to lower boost, I have this essentially new 9" Right Stuff booster that would not work with my setup. Seems to fit a 67 Bird.
https://www.jegs.com/i/Right-Stuff/9...10572/10002/-1
Old 04-16-2023, 12:20 PM
JLMounce JLMounce is offline
You want to try a single 9" (or 8" in it's available) in this application. The 11" and anything dual diaphragm is going to provide way too much boost in a full drum setup.
Was a power drum option even available on the first gens? I understand GM did that in the early 60's on big luxury barges, but I'd not heard of it being used on a much lighter F-body platform.
Another thing to look at here is which hole in the pedal you are using. It's hard to tell from the picture, but it looks as though the booster and master cylinder are level, instead of angled upward. If that's the case, it's possible that the upper hole with the higher pedal ratio is being used. Not only do you have a significant amount of assist from the large booster, but you've also got a lot of pedal ratio. All of that is working against you with drums all around.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 04-16-2023, 12:28 PM
Thank you JL.
The brake rod clevis is in the bottom hole on the brake pedal for power brakes.
The m/c is definitely tilted up. For that reason, I searched and found a NOS master cylinder with the bleeder valves on the master itself to aid in bleeding that air that can get trapped in the m/c.
As for original factory power drums on this car, I cannot fully say as I got the car as a project from out of state, 'seems' original.
Old 04-16-2023, 10:29 PM
Hotrod, that’s a better situation then. If you go to a single 9” diaphragm booster, you will reduce assist by roughly 33%.
That’s where I would start if I was in this situation.
What size bore is in the master cylinder? It’s probably a 1” or possibly a 15/16”. If you find after the booster change that you still have too much boost, you can go to a larger bore master cylinder. If it’s a 15/16” move to a 1”. If it’s a 1”, move to a 1.125” master. In each case you’ll increase pedal effort again by about 20-25%.
As long as the master is bench bled, tilting the master is fine as long as the fluid level is adequate.
-Jason
Old 04-24-2023, 01:55 PM
Thank you to all for your helpful advice. The solution was switching to a 9-in single diaphragm booster.
Now I have a good pedal, not an on-off breaking from overboost.
Old 04-24-2023, 03:30 PM
glad to hear you're back on the road with better functioning brakes.
-Jason
