Old 04-20-2023, 09:19 PM
alsalp alsalp is offline
Default 1971 axle backing plate gaskets
Do 1971 8.2 axles use gaskets between the backing plate and the tube flange like earlier axles? I ask because when i search at auto part stores and suppliers it does not come up. Sounds silly. I know earlier (68) axles have seal in the housing with a sealed bearing outboard. My 71 has the seal on the axle on the outside with an oil fed open bearing.
Old 04-20-2023, 09:58 PM
'64-late 69 used sealed axle bearings, internal seal in each axle tube, Sealed Axle bearings, & a thin gasket between the axle housing & the backing plate.
Late '69 model on Firebirds, then finally A-bodies, bolt-in axle rears were mfg with tapered axle bearing & (outboard) external seal (71246). No thin paper seals with these LATE 8.2 Pontiac housings/rears or any '70 & later bolt-in axle A-body rearend.
Old 04-21-2023, 03:51 AM
Kenth's Avatar
Kenth Kenth is offline
I have found on 1964-69 Pontiac 8.2" rear ends #9777865 gasket is used to axle housing and #9774551 gasket is used behind bearing retainer.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-21-2023, 10:50 AM
Thanks, I really thought it might be dumb question. My car is a 68 but i cleaned up a 71 axle for it and when I assembled it I assumed it took gaskets. Are they gonna hurt anything?
