Brake proportioning valve
Hello,
I’m upgrading my 66 GTO to disc brakes off a ‘71 malibu. I have a proportioning valve from a ‘73 El Camino, disc/drum. I believe is a G-body. The rear brake cylinders are ‘66 GTO, I thing are a different diameter then the ‘71 Malibu. Can I use the ‘73 El Camino proportioning valve with this application? Should I look at adding an adjustable prop valve? Should I change out the rear brake cylinders to ‘71 Malibu, if it’s a different size. Pads, rotors, discs& hose are all new. Also new is the ‘71 master cyl & booster. (Don’t know the length of the pushrod) Do I have to educate myself better on Pascal’s Law ? Thanks for the input. Sent from my iPhone using Tapatalk |
If originality/appearance is not a concern - I'd jump straight to an adjustable valve.
Prop valves are tuned for each individual application, varying the holdoff, meter, split and slope pressures, based on vehicle wheelbase, CG location, and piston/wheel cylinder diameters. Buying a random prop valve and expecting it to work is a bit like buying a random carburetor and expecting it to work, without knowing anything about the idle settings, jets or other tuning considerations. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
K
