Old 05-16-2023, 08:47 PM
grd777 grd777 is offline
Default car overheating , need advice
have new rebuilt engine , new rad ,new water pump new everything . car is running hot about 220 not sure what to do
Old 05-16-2023, 09:09 PM
Sirrotica's Avatar
50 plus pages here talking about cast iron water pump impellers, but it may help you out, if not in that thread the cooling system section has a lot of good advice in it, and cooling system troubleshooting tips:
https://forums.maxperformanceinc.com...+iron+impeller
https://forums.maxperformanceinc.com...play.php?f=420
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-16-2023, 09:14 PM
What thermostat?
Make sure the water level is correct? No trapped air in system.
Also is the fan shroud there and original?
Which fan?
Old 05-16-2023, 09:24 PM
What thermostat?
Which fan?
have a 180 in it now, maybe air is trapped , fan and shroud are original
what is the best way to get the air out
Old 05-16-2023, 11:28 PM
Stuart's Avatar
Stuart Stuart is offline
What's the make/model/year car, and what engine does it have. Was it rebuilt to stock specs, or is it modified.
Old 05-17-2023, 01:07 AM
Formulabruce's Avatar
Air out, Put the car up on ramps and get it warmed up and keep the rad cap off.
How tight are your tolerances?
check the T stat housing with an IR gun. do NOT trust the factory gauges or sender.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 05-17-2023, 02:32 AM
1972 formula rebuilt and a bit modified engine
ok will try that, what is a ir gun what the timing
Old 05-17-2023, 05:21 AM
IR = infra-red heat gun.
Old 05-17-2023, 05:05 PM
i have a mild cam in it having trouble setting the timing, would this also cause to over heat
Old 05-17-2023, 05:45 PM
Possibly.
Retarded distributor timing will cause it.
Also a lean afr.
Old 05-17-2023, 06:26 PM
Sirrotica's Avatar
If the engine ran cool before it was rebuilt, I would be looking at what parts of the cooling system were taken apart, and replaced during the rebuild. Chances of a Pontiac becoming air bound, and not working the air out of the system would be unusual. New parts are defective occasionally so yes you could have a faulty thermostat.
This is exactly why I referred you to the posts in the cast iron impeller thread, as well as the cooling system section. You need to know how the cooling system works to figure out what could be causing the problems, guessing seldom works.
Pontiacs aren't well understood by the majority of engine shops and overlooking things like, the rubber bushing seals, and cooling tubes in the timing cover, as well as not checking the 2 plates behind the water pump impeller are things that need attention when taking them apart and restoring them and then re-assembling them correctly.
There are 100 reasons why the engine could be overheating, so throwing random ideas without having a troubleshooting plan usually gets you no where but really frustrated when trying to make a Pontiac Stratostreak run within the proper cooling parameters.
If you're having trouble setting the timing the balancer ring could be to slipped, putting the timing marks in the incorrect place. If the cam timing is off it will run hot, as well as not run well. Looking at things that were disturbed during the rebuild, is probably going to be more fruitful than taking random suggestions on he internet.
I'm trying to give you some wisdom from 55 years of making my living working on many Pontiacs, as well as everything automotive, from daily drivers to oval track race cars. Ultimately it's your car, and your choice, do what you feel will get it fixed timely.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-17-2023, 07:23 PM
Lee's Avatar
Lee Lee is offline
??? HOW are you having trouble setting the timing? Explain, please.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
ok but i will have to say that the engine builder has done many Pontiac engines and i will assume he has done ever thing correct. i thought this forum was to help each other out . i am not trying to solve my problem on the internet ,but just want to see if someone else has had any of these issues. like always i will figure this out on my own. i also have been working on cars since 1978. but i am no expert, thats for sure
thank you
Old 05-17-2023, 07:26 PM
when i tried to set it on the specs .i did not run properly ,that's why i mention that i have a mild cam and my have to adjust
Old 05-17-2023, 07:48 PM
You're talking ignition timing I think?
(not camshaft timing)
Old 05-17-2023, 07:49 PM
sorry yes
Old 05-17-2023, 08:27 PM
Sirrotica's Avatar
John, the point being that the cam timing could be set incorrectly when the engine was assembled. I have no idea, nor does anyone else know if the person that assembled the engine knows about Pontiac idiosyncrasies, or not.
There isn't an overabundance of information about all the circumstances proceeding the overheating, so most people are shooting in the dark with suggestions.
As I said there are 100 reasons an engine will overheat, throwing every circumstance out there that anyone on this board has run into in the last 50 plus years just confuses the issues. There needs to be a series of things to look at, in order to eliminate sources of problems.
Here is a troubleshooting diagram for engine overheating engines, notice how many possibilities there are. You need to have a system to check off, to find the cause/causes of the problem. Many times there are multiple causes of an overheating engine. Problems are taken in an order to isolate the causes, not just random guessing.
https://mechanicalboost.com/signs-of...e-overheating/
To the OP, believe it or not, I'm trying to give you a system to help you fix your car in the least possible time, with the least frustration. If you'd rather I not post, I'll not post again on your thread.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-17-2023, 08:32 PM
i do thank you for your input . just want to have a game plan when i work on the car this week end
Old 05-17-2023, 08:45 PM
Sirrotica's Avatar
A game plan is exactly what I was trying to demonstrate, eliminate one thing at a time, then move to the next. I'll keep an eye on the thread, and if I can assist you, I'd be glad to.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
