Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
You might be looking in the wrong place for wear. Never had a problem with receiver wear but have seen two hitches rip from the frame rails on motorhomes over time. On one the frame had sections around the attaching bolts break out and the other had the sections of the hitch crack and break loose. In both occurrences the hitch was pivoting by only the forward most bolts and they were close to total separation. Both of these hitches flat bolted up to the bottom of the frame rails with no side supports. The safety chains and break-away cables are only attached to the hitch and the hitch and trailer would have drifted away from the tow vehicle unimpeded. I suspect that the 6" drop hitches probably added a lot of leverage that helped with the metal fatigue.
Truck manufacturers are better at taking into account that large loads will be towed, but motorhome manufacturers don't realize that many of us are towing a lot of weight behind us.
Towing With A Motorhome
The towing capacity of a motorhome is
rated by the manufacturer. Unless the frame is engineered and reinforced specifically to be utilized as a towing platform it is not suitable as a tow vehicle. Jim
Click Here To See Where I Am Today |
The Following User Says Thank You to Trulyvintage For This Useful Post: | ||
When I bought a much newer HD I noticed the hitch was a 2.5 inch, vs the old 2 inch. Gm put an adapter sleeve in the truck to run 2 inch receivers. Besides this being " wobbly" None of my hitch pins were long enough. Some places have the longer ones, and I bought a full size 2.5 receivers instead of the sloppy sleeve.
The 2.5 is overkill for my 12k trailer, but Its Safe I guess. To me slop makes wear.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
But... When you purchase a motorhome and it comes with a Class III or higher rated hitch from the manufacturer it would appear that they have thought things out.
They're have been many racers that have sheared off the rear frame of motorhomes towing an enclosed race car trailer with a bumper hitch. That flimsy, light duty rear frame section on most motor homes, is only meant to hold up the floor and living area. Flexing it over the road constantly, with 5 plus tons of trailer hooked to it, usually doesn't work out in the long term.
Maybe there is an option to use heavier steel for that section when it's being built, but any of the rear frames I've looked at are way to light duty for attaching a class 3 hitch to. BTW, maximum class 3 is only to 8000 Lbs, most open trailers with a car on it, and equipment carried on them will likely be over, or near that rating. E trailer does caution putting high weight rated hitches on motorhomes because of the frame deficiency of most motorhome rear frame sections. I've seen, and heard of too many racers breaking motorhome frames to think it's a good idea. |
double shear area of 5/8" pin = .613 in2 Assuming 1018 mild steel cold drawn, the ultimate tensile strength = 63,800 psi Shear strength is around 57% of ultimate so it's about 36,000 psi. So the pin should break at about 22,000 lbs. A wise traveler should have a safety factor of at least 2 or 3. So the allowable load would be 7000-11,000 lbs. Better pin material (like an alloy steel) would bump those numbers up a lot. Eric
Looking further on some other sites I find specs of 21,000 lbs for 5/8 inch hitch pins. I've had to do some jacking on my 1900 built farm house and using a 20 ton hydraulic bottle jack, using a floor jack post, the adjustable pin started to deform the tubing before the pin sheared. From that example I'd surmise the mild steel would start to tear at the holes before the pin shears on a receiver hitch. Just an experiment I've run across in jacking my home up to where it was before everything sagged and settled in the last 123 years. The floor jack posts are rated at 18,000 lbs, much closer to Eric's calculations Bob, my apologies for citing the wrong information from E Trailer.com..... You'd think a business that specializes in trailer towing equipment would strive to have more accurate information on their website. Eric, thanks for some better calculations than E Trailer has posted.... |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Good Thread
So - if you tow ….
It is a good idea to have your tow vehicle inspected along with your tow hitch by an experienced “ meat & potatoes “ trailer repair/hitch installation/welding shop. If you haven’t had that done - schedule an appointment - it is also a good idea to have whatever trailer you are towing completely checked out as well. The frame - tongue - hitch - safety chains as well as the breakaway switch - trailer brakes - wheel bearings - spindles - hubs along with the tires & rims.. Jim
Now I really like that! I might have to buy me a couple (one for each truck)) I don't generally hear the clunk on poor roads, but do hear it a little bit at stops & take offs! God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Pontiac Transporter Bills' Auto Works Est 1983 & still going strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Ambassador Custom Lemans 1957 Chieftan 2dr HT 1964 Grand Prix 1966 Catalina Conv. 421 1966 Ambassador DPL 2dr HT 1966 Ambassador Cust. 2 DR HT 1967 Marlin 1967 Toronado 1973 Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS Coupe 2007 Cad XLR-V Supercharged Roadster |
The Following 2 Users Say Thank You to Bills Auto Works For This Useful Post: | ||
My apologies to all. I actually bought this clamp at a small business in California. https://www.hitchrider.com/nowobble.htm
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
The Following User Says Thank You to OG68 For This Useful Post: | ||
Ordered ONE, if I like it when it shows up, I will order a 2nd for the other truck! God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Very impressed...$9.95 shipping & it is already on its way! Hope the quality is as good as the customer service.
I will report back when I get the 1st one. God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Glad you got one Bill, someone that will put some serious miles on it that can have a good evaluation. Looks like a good idea, and def. wont break the bank. But personally, with pulling a trailer, the extra load on the truck, squeaking springs, extra axles moving up and down etc., I have my doubts that it will even be noticeable. Cant wait to hear back on the review.
The Following 2 Users Say Thank You to TAKerry For This Useful Post: | ||
Yep, looking forward to hearing what you think of it.
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
In an emergency a 5/8 grade 8 bolt has a shear of 90,000#. You could substitute one of those.
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
At the beginning of May the wife and I hauled a '61 Ventura body and frame and all manner of sheet metal in a 24' Haulmark from here to western North Carolina. We had to drive north to Memphis to meet someone to drop off some heads and a few other items and then went east across Tennesse to Bristol and then down towards Ashville. Tennessee has the worst highways I've ever seen in terms of the areas where the pavement meets every bridge and overpass start and end. I do not see how that trailer stayed attached to my truck all the way across Tennessee. Every time we went over a bridge or overpass the jolt was absolutely unbelievable. If a hitch pin or ball was ever going to snap that would have been the trip imo.
Hey Guys,
@TAKerry @dataway I have done my testing on the Hitchrider Clamp! First trip was 9300 miles on the Dually, second trip I switched it over the the 2500HD & put a little over 3000 miles on a trip with that truck. It worked GREAT & after both trips I removed it to inspect the area it clamped to so that I could see if it had moved at all.....It Had Not! I am really anal about my trucks & trailers & even a little slop in the hitch that causes a clunk to me is not acceptable. I have always shimmed my hitch/receiver with a thickness of metal that removed that minor play, now I don't have to! I highly recommend his product!!! https://www.hitchrider.com/nowobble.htm God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
#38
Class 3 Rating - 6000 pound rating
This product has a Class 3 rating.
A Class 3 rating is 6000 pounds maximum. If you install this aftermarket product on your tow vehicle - the legal GVWR of your receiver hitch assembly is reduced to a Class 3 or 6000 pound maximum tow capacity. No aftermarket product will mitigate receiver hitch looseness - it is the result of wear and tear. Jim
#39
This product does NOT have a class rating, since it has nothing to do with the actual weight or pulling of the trailer tongue!
The ad states that it FITS the Class III receiver! They have others that fit other class rated receivers. Most every factory installed trailer hitches have the 2 inch opening (up until the last few years anyway. Even brand new there is a bit of play (there has to be in order to slide it in) I don't even like that little bit. Both my trucks have V-5 rated hitches God Bless Bill https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Pontiac Transporter Bills' Auto Works Est 1983 & still going strong! 1955 Chevy Altered W.B. Gasser 1955 Nash Ambassador Custom Lemans 1957 Chieftan 2dr HT 1964 Grand Prix 1966 Catalina Conv. 421 1966 Ambassador DPL 2dr HT 1966 Ambassador Cust. 2 DR HT 1967 Marlin 1967 Toronado 1973 Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS Coupe 2007 Cad XLR-V Supercharged Roadster Last edited by Bills Auto Works; 07-28-2023 at 04:53 PM. |
The Following User Says Thank You to Bills Auto Works For This Useful Post: | ||
#40
Manufacturer Assigned Rating
All manufacturers are required to
assign a class rating to receiver hitches and accessories. The manufacturer determines the class of the device - not the customer. If someone wants to buy a Class 4 or 5 rated aftermarket device from this manufacturer it is available here for 2.5 inch receiver hitches: @ https://www.hitchrider.com/hitch-vise-fit-guide-25.htm Jim
