Used OEM 1968-up Harmonic Balancer & 1971-up Crank Pulleys
Used factory original 1972 455 harmonic balancer, will fit all 1968 and later applications except some later 1970s that used a small hub instead of a regular balancer. Seal area has the usual wear and needs a repair sleeve. The keyway isn’t cracked or damaged and the pulley bolt threads are good.
Located in Canyon Country CA 91387 $25 plus $17.20 USPS Flat Rate Shipping in the USA, it’s heavy so that’s about as cheap as it gets to ship this. PayPal (using friends and family), money orders and personal checks accepted. Please send me a PM if you’re interested, thanks. Any of the pulleys listed below can ship along with the balancer in the same USPS box at no additional cost. |
Twin-groove 1971-up crank pulleys and reinforcement plate. Pulleys are straight and exhibit very minimal surface rust in the grooves.
$15 for each pulley alone or $20 with the reinforcement plate, plus shipping. $10 plus shipping for the reinforcement plate by itself. |
Single groove air conditioning pulleys that sandwich behind the twin groove crank pulley. Straight with minimal surface rust in the groove.
$10 each plus shipping or $5 each when purchased together with one of the twin groove pulleys. |
Balancer is sold.
Pulleys all still available. |
Both twin-groove crank pulleys and the reinforcement plate are sold.
The 2 A/C pulleys are still available. |
Thread Tools | |
Display Modes | |
