Tri-Power Tech 57-66 Tri-Power Talk
Old 06-05-2023, 04:29 PM
gtorich gtorich is offline
Default 66 tri power fuel line
Been running a stainless steel hose with the rubber inside it for many years on my 66.............checked with ames today and they do not have a hard line from the fuel pump to a carb on a non tri power car.............thought that was strange since they have them for 64-65-67 & up..........they said only rubber lines were available.
Just wondering if any of you guys are using a hard line then only a little rubber on top to the carb.................
Rich
Old 06-06-2023, 03:10 AM
Kenth's Avatar
Kenth Kenth is offline
Originally Posted by gtorich View Post
............checked with ames today and they do not have a hard line from the fuel pump to a carb on a non tri power car............Rich
Yes they do, part-# N129B.
1966 Tri-Power uses a 3/8" hose from pump to filter on front carb.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-06-2023, 08:55 AM
Thanks Kenth.............i have that part, i thought i could get something like the one they have for the a/c cars N129bk.
Will just run the stainless hose , mine is pretty old so will have to get some more.............dont know if it would make much difference if something hit the line one way or the other.............
Rich
