Old 06-06-2021, 06:45 PM
gtobird's Avatar
gtobird gtobird is offline
Default Immediately need rear leaf spring eyemount J-Clips for 68 bird - in Metro Milwaukee
Help! I'm trying to get my 68 bird rolling so I can load it in the trailer and move it. I need some of the J-Clips that are inserted into the rear frame rails that the spring eye mount bracket bolts go into. Yes a common item among the usual classic car parts dealers, but I need them almost immediately. The car is in metro Milwaukee so I would like to buy them locally if possible. I tried all of the regular auto parts places. No-one has these.
Any ideas? I'm thinking maybe National Spring????
OJ
Old 06-06-2021, 07:21 PM
67drake's Avatar
67drake 67drake is offline
It might be hard on a Sunday, but my local hardware store sells a small variety of them. Might not be the exact size or style as original, but should be good to get it rolling.
I would think a Menards would have them. They are usually open till 8 or so on a Sunday
13.95 @ 102.1 on street tires @ 4055lbs.
Old 06-06-2021, 07:34 PM
67drake's Avatar
Or Lowe’s
https://www.lowes.com/pd/Hillman-5-1...ng-Nut/3013214
Old 06-06-2021, 07:48 PM
gtobird's Avatar
I appreciate the suggestions, but I have plenty of wrong hardware already that would work if I didn't care about it looking correct. I have a tremendous amount of detailing in the rear springs and rearend and I only want to install it once. If I can't find the right stuff locally, I'll have to get some of the right stuff overnighted., Again, I do appreciate the comments.
Old 06-06-2021, 09:00 PM
nashcar nashcar is offline
Lowes, Napa, Body shops.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 06-06-2021, 09:14 PM
67drake's Avatar
Ah,OK. My impression from your post was you needed to load it on a trailer only. I figured correct parts could be found later.
Old 06-08-2021, 02:55 PM
max 93 max 93 is offline
Did you try Butler Classics?
