Old 10-13-2021, 12:34 PM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
Default Torque Convertors
What brand convertors is everyone using for a street strip car?
1978 Trans Am
TH350
Pontiac 455 with forged rods/pistons
Heads ported to 250 cfm
9.5 compression
Quadrajet carb
3.23:1 posi rear.
Redline Design
Old 10-13-2021, 01:15 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I'm very happy with my custom 10" PTC. Flashes to 5000 yet still drives nice on the street.
'68 Firebird
463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
9.93 run - https://youtu.be/hII0_UlYM4U
Old 10-13-2021, 04:38 PM
Scott Stoneburg's Avatar
TransSpecialty 9" converter in my 67 Firebird.
Old 10-13-2021, 06:29 PM
AG's Avatar
AG AG is offline
Redneck Racing 9.5", flashes to 5000 rpm and has 6.8% slip across the stripe.
Old 10-13-2021, 07:53 PM
chuckies76ta's Avatar
TCS and flashes to 5000 rpm. I hear the PTC converters are the hot ticket..
Old 10-13-2021, 08:07 PM
pastry_chef's Avatar
ptcrace.com
Most widely used by the fastest Pontiac racers. Make awesome street converters as well.
Old 10-13-2021, 08:56 PM
BILL BOWMAN1's Avatar
I have used and been happy with ATI and Dynamic.
Mike Davis's Avatar
PTC, call and ask for Lane.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 10-14-2021, 12:26 AM
Dragncar Dragncar is offline
Lane is the man. 9" PTC picked up .015 over a 8" TCI that was 400-500 $ more..
Old 10-14-2021, 12:33 AM
Probird's Avatar
Probird Probird is offline
I've had great results with both BTE and FTI. Super consistent converters
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 10-14-2021, 08:21 AM
Mr Anonymous's Avatar
Ive used Ultimate Converter Concepts (Lenny) 10" with great success. Changed combos, trying a brand new PTC 8" probably tonight if the weather holds.
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 10-14-2021, 08:54 AM
Thanks Guys! I am going to give PTC a call today.
Redline Design
Old 10-14-2021, 03:48 PM
Talked to Lane at PTC, in about four weeks I should have a torque convertor.
Redline Design
Old 10-15-2021, 07:55 AM
If and when you get the converter installed, can you post some feedback. Much appreciated.
Old 10-15-2021, 10:59 AM
Took my car out last night with the new PTC converter. It scared me, I almost peed a little, and the car gets wheelie bars. Holy cow.
Clutch Guys Matter
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 10-15-2021, 11:15 AM
grandam1979 grandam1979 is online now
Faster slower difference??
Old 10-15-2021, 12:49 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I don't think people normally piss their pants from slowing down.
Old 10-15-2021, 01:21 PM
Only if you really have to go and the rest stop is too far away!!!
I will post some feedback when I get it installed. Motor should be back in a few weeks so we will see if I get it all together before the snow flies.
Redline Design
Old 10-15-2021, 03:12 PM
JSchmitz's Avatar
Touché!
Old 10-15-2021, 03:19 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
depends on HOW FAST you decelerate!!!! Speed has never killed but those sudden stops sure do
