Old 10-20-2022, 04:11 PM
Originally Posted by jm455ho View Post
When I was running 11.0X's, my 60ft times were 1.38-1.39. My 1/8 mile was 6.90's @ 95 mph, and 1/4 mile was 118 mph. This is leaving on trans-brake with 4:30 gears and 9x30 radial slicks.
This year with around 45-50HP more, I made a few test hits and best was 1.33 60ft, 6.63 @ 99.65 mph, and 10.59 @ 123 mph. Engine dyno'd around 520HP and race weight is 3350 lbs.
What trans and converter do you run? To me your car is very fast for the mph. Your 60’s are impressive.
Old 10-20-2022, 04:55 PM
Dragncar Dragncar is offline
Those are some nice numbers. You are getting the power you have to show up. Can you tells us more about your combo ?
Old 10-20-2022, 05:26 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
That’s flat getting after it out of the hole 👍🏼
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 10-20-2022, 06:24 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Car specs:
1978 Firebird Trans Am, all metal body, all glass windows
Moser 9 inch rear end, 35 spline axles, spool, 4.29 gears
10 point chromemoly cage
Cal-Tracs split mono leafs with bars
QA1 double adjustable rear shocks
Martz Chassis front subframe with QA1 double adjustable shocks
Weld Aluma-Star 15 x 10 with Hoosier 30 x 9 radial slicks in back
Weld Aluma-Star 15 x 4 with Hoosier front runners
JPT C4 transmission with JW Ultrabell (GM to Ford C4) with Transbrake
JPT 10” converter, 4600 rpm stall
Weight with driver: 3350 lbs
www.hobracing.com
The Following 3 Users Say Thank You to jm455ho For This Useful Post:
Old 10-20-2022, 06:31 PM
jm455ho's Avatar
Current engine specs
4.150" bore x 4.0" stroke based on 1978 XX400 block (433 CID)
Studded 2 bolt mains with Canton road race oil pan.
250° - 256° (@ 0.050”) solid flat tappet cam, 112° LSA installed at 108
Ported #12 casting iron d-ports with Ferrea valves and beehive springs 166-168 cc intake runners, 70 cc chambers. (11:4 comp ratio)
Cast iron intake plenum ported with Q-jet and 1" spacer
Heddman 2" headers
Intake rockers: Harland Sharp 1.65 (measured 1.72) net lift after lash .570"
Exhaust rockers: Harland Sharp 1.50 (measured 1.58) net lift after lash .520"
Cranking pressure: 190psi
Dyno'd at 520
www.hobracing.com
The Following 2 Users Say Thank You to jm455ho For This Useful Post:
Old 10-20-2022, 08:42 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Nice job. Those are some great #s for your combo. I think the steep gears and good traction are getting you out of the hole with an impressive 60' time but probably slowing the mph relative to the e.t. In any event you are doing way better than most other combos I have seen that are similar to yours.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet.
Old 10-21-2022, 09:03 AM
Stan Weiss's Avatar
Heddman 2" headers
Dyno'd at 520
Can you post up the dyno sheet?
I collect dyno sheets. I have a dyno from you from 2014 which shows 478.7 HP @ 5400 RPM. I also have a dyno which I have labeled as your from 2017 which shows 784.7 HP @ 6800 RPM
Thanks,
Stan
Pontiac Pump Gas List
Old 10-21-2022, 12:21 PM
jm455ho's Avatar
Thank you
www.hobracing.com
Old 10-21-2022, 01:48 PM
jm455ho's Avatar
If anyone wants to have copies of the dyno sheets that are indicated below, send me your email address in PM, and I will forward them. They are too large to attach here, unless someone knows how to do it.
HOB Dyno sheets
Hob24 – RPM - Qjet 800 stock 2 ring version - 32° total timing
Hob25 – RPM – Race Qjet single ring version - 32°
Hob26 – RPM – Race Qjet – 32° - air flow meter
Hob27 - RPM – Race Qjet - 34°
Hob28 - RPM – Race Qjet - 36°
Hob29 - RPM – Race Qjet - 38°
Hob30 - RPM – Race Qjet - 40°
Hob31 – RPM – Holley HP750 – 38°
Hob32 - RPM – Holley HP750 – 38° - air flow meter
Hob33 – Torker 1 – Holley HP750 – 38°
Hob34 - Torker 1 – Holley HP750 – 38°
Hob35 – Warrior – Holley HP750 – 38°
Hob36 - Warrior – Holley HP750 – 38°
Hob37 – Ported Hurricane – Holley HP750 – 38°
Hob38 - Ported Hurricane – Holley HP750 – 38° - Shaker assembly w/Blockers air cleaner
Hob39 – Plenum ported iron intake – Race Qjet – 38°
Hob40 - Plenum ported iron intake – Race Qjet – 38° - WFO air cleaner – paper element
Hob41 - Plenum ported iron intake – Race Qjet – 38° - WFO air cleaner – K&N element
Hob42 - Plenum ported iron intake – Race Qjet – 38° - WFO air cleaner – paper and K&N elements stacked
Hob43 - Plenum ported iron intake – Race Qjet – 38° - GM air cleaner – K&N element – ½” spacer under air pan
Hob44 - Plenum ported iron intake – Race Qjet – 38° - GM air cleaner – K&N element – ½” spacer under air pan
Hob45 - Plenum ported iron intake – Race Qjet – 38° - GM air cleaner – K&N element – ½” spacer under air pan
Hob46 - Plenum ported iron intake – Race Qjet – 38° - air flow meter
Intake configurations
RPM intake
1.25” spacer with opening on secondary side
Plenum depths with spacer – 3.5” / 5.5”
Torker 1 intake
Primary plenum depth – 3.75”
Secondary plenum depth – 3”
Open spacer – 1.5”
Plenum depth with spacer – 4.5” / 5.25”
Warrior intake
Plenum depth – 2.25”
Open spacer – 2.75”
Plenum depth with spacer – 5”
Ported hurricane intake
Rear plenum depth – 3.5”
Front plenum depth – 3.0”
Tapered open spacer – 1.5” / 2.0”
Cast iron intake
Plenum ported by SD Performance
Port matched by me
1’ spacer open on secondary side
www.hobracing.com
Old 10-21-2022, 01:51 PM
jm455ho's Avatar
Thanks,
Stan
The 2014 results were from the same engine as now, but with stock non-ported heads. The 2017 results were from an aftermarket block with ported high ports that I built, but eventually sold.
www.hobracing.com
Old 10-21-2022, 02:18 PM
Stan Weiss's Avatar
HOB Dyno sheets
RPM intake
Torker 1 intake
Open spacer – 1.5”
Warrior intake
Open spacer – 2.75”
Cast iron intake
Port matched by me
Since my email address is posted all over the internet one place will not hurt. lol srweiss1@comcast.net
Thanks,
Stan
Old 10-21-2022, 02:50 PM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
This is a fun thread...I've run 3 Drag weeks
ran 12.6 ave 1st one 2019
ran 11.8 ave second one 2021
ran 10.7 ave this year and had a pb 10.55 attached
70GTO Stick shift car
535 ci w/ tiger heads
3585 lb raceweight
4.10
29.5 x10.5 tire
5000 launch
I think it needs 4.56 gear but reluctant to change out my trutrac carrier.
Name:	InkedDrag week PB 2022 mu.jpg
[SIGPIC]
Steve
The Following User Says Thank You to XLR8STEVE For This Useful Post:
Old 10-21-2022, 08:26 PM
AG's Avatar
AG AG is offline
3585 lb raceweight
4.10
29.5 x10.5 tire
5000 launch
Very impressive with a stick car. What trans do you use?
Old 10-21-2022, 11:51 PM
Originally Posted by slowbird View Post
That's great thanks for sharing!
Just curious what was your 330ft on the 7.18@94mph pass?
1.560 60 ft
4.584 330 ft
7.189 660 ft
1972 Pontiac LeMans
Thanks to
Old 10-22-2022, 12:05 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by adam woodmancy View Post
1.560 60 ft
4.584 330 ft
7.189 660 ft
Awesome thank you so much for looking that up.
The intriguing thing to me is our 69 GP ran same from 330 to 660 (2.60) If we can get the weight moving quicker we should have teens in it. Got something to work towards now.
Ours 1.62 4.696 7.301
The Following User Says Thank You to slowbird For This Useful Post:
Old 10-26-2022, 02:33 PM
15bhardwick 15bhardwick is offline
Was 1.55 60ft 6.99 1/8 11.12@ 119
Switched from an 850 holley to a 1000cfm APD 4150
Now 1.60 60ft 7.02 1/8 11.05@121
4,000 converter
4:56 gear
3350lb
footbrake
The Following User Says Thank You to 15bhardwick For This Useful Post:
Old 10-26-2022, 06:09 PM
RBAILEY RBAILEY is offline
Old 462 w/Iron D combo -
10.60s/10.70s best 60 of 1.48 but usually 1.51 to 1.55
4000 converter
3.73 gear
3295lb
transbrake
But now I have a 60ft problem as I'm running the same 1.51 60ft on a 10.16 @ 135.63 now with new 474 w/high port combo .. should be like 1.37 now...going to swap to a Victor from a Gutsram to see if the 60 improves
The Following User Says Thank You to RBAILEY For This Useful Post:
  #38
Old 10-27-2022, 11:52 AM
I would really like to change intakes on mine to see how it effects it. When I got my e-heads used, they came with a matching 4150 Victor intake and that’s all I’ve run since I got them. The last time my heads were at the machine shop, I took my old Torker II in and asked the guy to try to do whatever needed done to make it work with the heads. For whatever reason, he said it couldn’t be used with the heads. I don’t know if there’s truth to it or if he just didn’t want to mess with it, but I’m certain that given the small cubic inches of the motor, the weight of the car/lack of gear and very limited rpm’s that it would perform better with an rpm performer or torker II. Not to mention with my flat hood and the victor, I have to run the carb right on the intake. I think an rpm with a spacer would run better. Any thoughts?
1972 Pontiac LeMans
Thanks to
  #39
Old 10-27-2022, 02:21 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Hi Adam. We spoke in the staging lanes at Havana a few weeks ago. Ive never tried a victor but my car picked up from 7.5 to 7.3 going from an extrude honed TII and 1/2" open spacer to an RPM manifold with no spacer. Possibly i didn't have enough spacer on the TII but i don't have the clearance for a bigger one. Jon
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
  #40
Old 10-27-2022, 03:26 PM
jm455ho's Avatar
I would almost guarantee you will run quicker with an RPM (and probably a TII). Are your heads wide port version?
www.hobracing.com
