Old 06-27-2023, 04:41 PM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default racing idle
Ok guysI am having a problem with my engine.67 400,I just rebuilt my carter carb ( or tried too) the eng races I can't get it to idle. Please if anyone has any ideas I would greatly appreciate it.I want to set the timing but it races too fast.
Thank you,Tim
Old 06-27-2023, 05:06 PM
Scott Thelander's Avatar
Choke cam is stuck
Or
Vacuum leak??
Old 06-27-2023, 06:54 PM
bhill86's Avatar
bhill86 bhill86 is offline
Or timing already advanced really far?
1977 Trans Am 400/4speed (swap)
Brian
Old 06-27-2023, 07:51 PM
Sounds like he only worked on the carb
But
I’m sure he’ll reply back
Old 06-27-2023, 08:01 PM
mgarblik mgarblik is offline
67 Carter 4bbl. carburetors use some unique gaskets between the carburetor base and the intake manifold. This includes a stainless steel shim gasket along with the paper one to close off the carburetor heat passage in the intake manifold. You must have the correct gaskets for a 67 model or you will have a large vacuum leak and a fast idle. Be sure all that is correct. Your rebuild kit may not have included all the correct gaskets and the sheet metal shim .
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
Old 06-28-2023, 09:20 AM
Default racing idle
Thank you guys,actually I've been trying to get this car running right for a long time. new hei dist ,electric fuel pump, 11 bolt water pump,dual electric fans.
I removed the manual fuel pump. A bit overwelming,does anyone know where I can get a correct rebuild kit or maybe someone to rebuild it.Sorry about the rant but thank you guys for all you're help always a great bunch of guys.
Tim
Old 06-29-2023, 01:42 AM
Geoff Geoff is offline
Does this carb have a large brass screw, front centre? If so, it is for idle speed. It controls AIR & acts like an air leak. Screw in to reduce idle rpm.
Old 06-29-2023, 04:52 AM
Kenth's Avatar
Kenth Kenth is offline
A 67 GTO would use a Quadrajet (mfd by Carter).
My bet is that the stainless steel heatshield to throttle plate, on flange gasket, is missing.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-29-2023, 01:27 PM
Default racing idle
Thanks Geoff and Kenth,would a vacumn leak to the pwr brakes cause this?I'm not at the car now,but will look for that brass screw tomorrow I don't remember a brass screw.Thanks again guys.
Tim
