Old 12-07-2003, 09:37 AM
Rzepka_R Rzepka_R is offline
I imagine this has been talked about before, but in a different way, for that I apologize... I've got a 1964 Lemans that I'm building to be a stout street car. Car is complete except for an engine, plans are to have KRE build a "mild-monster" for it. Something right around 500 horsepower with a "new" muncie behind it.. Question is: Stock tank with stock pick-up, larger 3/8" stainless line to front, and a want to use a mechanical pump like a Carter -- will this be able to feed a 500 horse motor? Maybe I'm wrong, the SD's in the early 60's only modification to the fuel system was an increase in spring pressure for the mechanical pump, those ran, didn't they?
66 GTO Htp -- # Matching Tri-Power/4 speed/Barrier Blue/Black Interior
Currently running a 461/KRE D-port/Hydraulic Roller/Tri-Power/Super Case M22
Old 12-07-2003, 09:49 AM
tom s tom s is offline
the SD pump was NOT a drivable pump,it made 12lb pressure.Tom
Old 12-07-2003, 10:17 AM
JEFF KING's Avatar
JEFF KING JEFF KING is offline
I run 422HP dynoed at the fly wheel with the stock line/carter pump never any trouble(New tank,sock pick-up)It should hold up to 500HP.
Ask this in the racing section see what they say.
"GTO? "Get Tools Out!!!"
"And he Asked, Who Owns This Car? With The Peace Sign, Mag Wheels, and the Four on the Floor??
Old 12-07-2003, 12:00 PM
GONZO's Avatar
GONZO GONZO is offline
Yes it comes up every 3 weeks actually:
carter pump, New/cleaned tank, new/no sock pick-up, and a 1/2" line and you should not have much probs.
RAIV Don't leave home without it.
www.kingofmusclecars.com
http://www.stockappearingdrags.com
Come on get off that lawn chair and drive that car like it was meant to be driven.
69' 400 RAIV Judge Conv... 12.86@107 Factory Stock
69' 400 RAIV Trans AM .....12.48@110 Factory Stock
69' 400 RAIV Judge HT..... 13.07@104 Factory Stock
73' 455 SD Trans AM........13's?? not run yet
66' 455 GTO Convert.........12.20@112 non original
63' 421 SD Catalina...........restored fast as h*ll
Old 12-07-2003, 03:57 PM
Thanks for the help guys, I also took the advice to post it in the race section... Thanks Again!
