Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Just keeping this in sight!!!!!
Don Johnston DCI MOTORSPORTS LLC 330-850-5050 shop 330-628-3354 cell Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
test...
What header flange do the Ram Air V accept? From the pictures it looks alot like a BBC.
The RA 5 's have their own exhaust flange and spacing. Although the BBC is close and can be modified to fit. The only thing that might hamper using BBC headers in a stock chassis would be the starter is on the opposite side. So one of the tubes may need to be moved to work. So a better alternative might be to use a RA 4 header and modify it to fit. I have seen this done with good success.
Keeping this up top!!!!!
Hump Day Bump!!!!!
Bump for spring !!!!!
My Deposit check was mailed in today.
I secured my set of Ram Air V heads. Steve |
Thanks Steve!!!! Your set is secured.
Bump for Spring!!!!!
Don: What kinda fuel supply can be used with this intake? ex: Carb, EFI,
Thanks Charles
I'll be using EFI.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Yes !!! All the above. I cast bosses on the runners for fuel injection or Nitrous. So it is ready for FI, Nitrous, or Carburetor(s) 1x4, 2x4's, 3x2's. That is also why I cast it without a top. It can even be used for a roots style blower.
Thanks again Don..
Charles
Back to the top!!!!!!
