Industry Stuff new repro's, updates, other info.
Old 03-18-2017, 05:10 PM
BierManVA BierManVA is offline
I commented in another thread about this. Mine was warped as well but installed fine. It will have some gaps though once in the shroud. I kept mine as it fit OK. They will accept a return though.
Seems to be a known issue.
Old 03-18-2017, 06:21 PM
GT182's Avatar
GT182 GT182 is offline
How bad are they warped? And is the upper and lower hose mount size the same as the Harrison radiators for 65 thru 67 A-bodies?
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 03-18-2017, 08:55 PM
Mine was warped about 1/2-3/4". Don't know about those years for the radiator hose size but for mine (1970 GTO) they were correct.
Old 03-18-2017, 09:01 PM
1969GTO's Avatar
1969GTO 1969GTO is offline
My upper hose size was/is to small. I have to double clamp the upper hose to the radiator.
color me gone
Old 03-18-2017, 09:08 PM
Did you have an issue with the transmission cooler lines? I have the standard 5/16" line but it does not fit into the transmission cooler end. I sent an email to Cold Case but have no idea what size they used or what adapter I will need.
Old 03-18-2017, 10:21 PM
1969GTO's Avatar
my stock trans lines were not a problem.
color me gone
Old 03-20-2017, 11:09 AM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
The trans line fittings were supplied for early production 2015-2016 radiators.
We have since gone away from supplying the adapters. That's why some are fine and some need adapters.
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
