Old 07-25-2016, 06:18 PM
darbikrash darbikrash is offline
Default SD scoop info
Can anybody share any details on the Super Duty hood scoop as seen below? I'm considering putting one on my '64 2+2, as a tribute, since it now has a 421. The pic is a '63, but that is the scoop.
Where to get one? Is there a hole in the hood or how are they attached? Is there an underhood seal or other attachment details?
Any info or sources?
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 07-25-2016, 06:28 PM
tom s tom s is offline
The scoop is-was a ford truck scoop.That grill in the picture was-is not correct on a pontiac.Only the scoop is.There is nothing on the hood to help you place it,nothing in any pontiac factory lit either.You just place it where the carbs are centered in it.It has studs on it that are used to fasten it to the hood.I used a rubber gasket material I bought from West Marine for it.Tom
Old 07-25-2016, 06:47 PM
Thanks Tom. Did you cut a hole? If the grill is incorrect- is it left open or is there something else there. Also, it seems that there are several sizes, can you advise correct dimensions?
Old 07-25-2016, 06:51 PM
marxjunk marxjunk is offline
the stock scoop is small...i have used the the large one pic'd above..looks much better
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-25-2016, 06:52 PM
There is-was only one original metal ford scoop.There are aftermarket glass ones.They show up on ebay all the time.Should not have to pay more than 75-90 dollars for them.I think I bought them from ford when they still had them for under $30 brand new.And yes I cut the hood for it.Tom
Old 07-25-2016, 10:00 PM
Stuart's Avatar
Stuart Stuart is offline
You may be lucky enough to find one on a Ford truck in a salvage yard somewhere. Look for a 1958-1960 heavy duty truck, something like a dump truck.
Old 07-25-2016, 10:48 PM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
I have the scoop you are looking for. I bought it when I was working on a 63 Tempest but never finished the project. In good shape. I would take $225 plus shipping. If you are coming to Norwalk I will bring it there.
Old 07-26-2016, 09:36 AM
cruzingratiot's Avatar
cruzingratiot cruzingratiot is offline
ford truck scoop
ID:	433549   Click image for larger version
Donate Life
6-7-04 Liver Transplant Recipitant
http://www.donatelife.net/ U S A for Organ Donation
Thank You
Old 07-26-2016, 01:18 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Yep, just have to guess to mate.
Old 07-26-2016, 02:42 PM
Stuart's Avatar
Originally Posted by cruzingratiot View Post
ford truck scoop
Interesting. That looks like about a '67 or so, I didn't know Ford was still using them that late.
