Old 03-23-2018, 11:30 PM
Tinkerer Tinkerer is offline
Default 1974 Full Size Limited Slip Differential, 2.93, $125.00, Near Gettysburg, PA
Removed from running/driving Catalina back in the mid 1990's. Has been sitting around since.
Thanks,
Bill
Fairfield, PA 17320
ID:	478831   Click image for larger version
Old 03-24-2018, 10:14 AM
GpFreak's Avatar
GpFreak GpFreak is offline
Post
Do you know if this will bolt into a '67 full size?
Steve Naresky
Old 03-24-2018, 05:54 PM
I have no idea. I can measure the spring and control arm mount locations if you want.
Does your drive shaft have this type of mounting flange?
Thanks,
Bill
Old 03-25-2018, 09:45 AM
GpFreak's Avatar
Post
Hmmm... no, mine has u-bolt style. That looks like a Ford flange.
Steve Naresky
Old 03-25-2018, 12:43 PM
The drive shaft had a double u-joint at that end.
Old 04-04-2018, 01:29 AM
monzaz's Avatar
monzaz monzaz is offline
Default WHAT DOES IT FIT
This rear is for all 1971-1976 FULL SIZE Pontiac Buick Olds chevy
WILL not fit early wagons that are leaf spring.
Will not fit 1965-1970 Full size cars. Shocks mount in the back...1971 -1976 shocks mount in the front...there are other differences also spring perches axle spline is 31 but not the same pitch as the older 65-70 31 spline pitch axles.
Hope this helps the sale. Jim
J D
Jim Mitschke
J D Race and Restoration
Richfield, Oh
JDRACE3@GMAIL.COM
Old 04-23-2018, 05:37 PM
skipp65 skipp65 is offline
Do you still have this?
Old 04-23-2018, 06:01 PM
Yup.
Old 04-23-2018, 06:22 PM
Your about 2.5 hrs away from me, would you take $100? I could pick it up tomorrow eve if that works for you?
Old 04-23-2018, 06:34 PM
PM sent.
Bill
Old 04-24-2018, 09:58 PM
Sold.
