Stefs 1240 Pan in First Gen Firebird
I’m planning on modifying my front stub to fit a Pontiac V8 In its stock location fore and aft. I am going to cut both of the stock crossmembers out and install 4130 Plate and 1-5/8” tube just inside of the factory control arm attachment points. I am installing a mustang rack so I have to install the mounts for it in one of the horizontal tubes that I will install. Of course, before cutting the subframe I’ll be adding some substantial bracing to keep it square as it was (not very). Yes I know camber is off, playing around with upper ball joints and haven’t used any shims. I’ll probably cut my own one-piece shims on my CNC machine.
Anyone modified their crossmembers and have photos of how much you took out? I need clearance for a Stefs 1240 pan. Just wanted to get some dialogue going before I start fabrication. I’m using All Pontiac 3/16” steel front and mid plates and a Innovative Racecraft Chromoly TH400 Trans Crossmember with a Poly mount on the trans. Also anyone have a trashed 1240 Stefs I could use for mock up? Sent from my iPhone using Tapatalk |
What I did to mine.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
74 GTO, same subframe
69 Firebird Subframe.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Curious how long it takes to get one of these pans now days?
I got mine in about 6 weeks and that was well after Covid started messing things up. Called Canton first but they could not make me a race pan at all due to Covid.
They guy who built them was out. |
Mine was similar to this, added tabs so I could unbolt to remove pan in car.
Honestly don't even think I needed it, bolts slid in and out easily on the ground or on the lift.
Dave Polichena |
68 bird fabrication. Oil pan is removable.
I keep it bolted in, but it's probably not necessary. |
Just called today. There 6-8 weeks out. I have one that had a rod threw it and was repaired. Want to sell it so I can buy a new one! Sent from my iPhone using Tapatalk |
I have one that had a rod threw it but is fixed. Plan on selling it. Sent from my iPhone using Tapatalk |
I have one as well, would be removable if I didn’t have to use so much gasket sealer! Haha Also, what kind of socket did you use to put in the 4 recessed nuts. I had to use a belt sander and grind my socket down to almost nothing! Sent from my iPhone using Tapatalk |
I messaged you about it. What’s your price? Sent from my iPhone using Tapatalk |
I had The Right Stuff all over and the 3/8" set would not fit. I had to scurry around and dig out 1/4" stuff before it dried. Had a crank scrapper in there too. Would have been a mess if I had to disassemble and re do. |
I would take $400 for it. Sent from my iPhone using Tapatalk |
