cylinder head/exhaust manifold heat shield mounting
I have a 70 TA RA III and I'm building a motor with Edelbrock heads. I want to keep everything looking and functioning as close to stock as possible. For the heat shield/riser (not sure exactly what it's called) What is the best way to do that with the Edelbrock heads? Use the original bolts/studs, or get a new set of original style? The Edelbrock bolts are not studded. ARPs are not studded. Have studs welded onto ARPs?? Or just say forget about it and move on 'cause it's not stock anymore anyway?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
The latter !
The Following User Says Thank You to steve25 For This Useful Post: | ||
Damn... I knew I should have left that option out...
It's really your own personal preference and what you want the engine bay to look like.
Me personally, I go through the extra trouble to make things like this work for a stock appearance. I always do the heat shield and ductwork, even if it's non functional, I still make it appear that it works. |
The question is, what is the best way to do it? So if ARP bolts would be better, I could use JB Weld to attach studs, or just use the stock bolts with studs.
I don't have any pictures but have done the heat shields on a few E-D port heads. I have tig welded a stud on the ARP bolt heads. Just use a deep socket to torque the bolts.
There is a guy up the road that just did this and made some washers with tabs to go under the head of the bolt that he can bend over after torquing and use a self tapping screw. JB weld will not work.
As said above or another option, ARP sells studs with a smaller attached stud on top. If they offer the length you need that might be less hassle than welding studs to your existing ARP bolts.
