Old 11-05-2022, 02:09 PM
cnc's Avatar
cnc cnc is offline
Default Furnace issue need hvac help
I've got an Olsen furnace for my garage it loos like a regular old house furnace and it's age is unknown we've been here 18 years so it's that old at least...
I've started to notice the furnace continual runs and blowing cool air...pilot light is on and blower motor running....where do I start to look for an issue....
Any help appreciated.....Chris
ID:	601731   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 11-05-2022, 03:26 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
no gas, try replacing the thermocouple.
Old 11-05-2022, 03:33 PM
cnc's Avatar
cnc cnc is offline
Pilot light is light and running still thermocoupler ????
Old 11-05-2022, 05:43 PM
Mr Twister's Avatar
No probably not . Im not a pro so i dont want to tell you to buy a gas valve that might not work
Old 11-05-2022, 08:07 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Either main gas solenoid/valve or an ignition limit switch. Electronic damper by chance?
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 11-05-2022, 11:04 PM
cnc's Avatar
cnc cnc is offline
Electronic dampner I think it's too old to have Electronic stuff in it...
Old 11-06-2022, 09:43 AM
4dblnkldude's Avatar
That thing is early 80's. I know you probably don't want to hear it but pony up and buy something safer.
Old 11-06-2022, 10:06 AM
indymanjoe's Avatar
Is the knob on the gas valve set to pilot off or on? seen it set to pilot on a couple no heats through the years lol
Old 11-06-2022, 01:57 PM
cnc's Avatar
cnc cnc is offline
your right it’s 84 Ithink isn’t it…wouldn’t. Mind getting rid of it to something I can hang that give me more room…any suggestions
Old 11-06-2022, 01:58 PM
cnc's Avatar
cnc cnc is offline
Nope furnace never gets touched…summer or winter it just stays on
Old 11-06-2022, 02:05 PM
cnc's Avatar
cnc cnc is offline
Well having a hvac guy coming out to inspect …
Old 11-06-2022, 07:36 PM
You can hang an 80% furnace horizontally. Or a 90%+ furnace. If you do a 90+ you cannot install it where it would be below freezing.
Old 11-06-2022, 07:58 PM
Mr Twister's Avatar
Correct. I heat my garage with an 80 percent natural gas unit i bought new from an auction where they sell new furnaces that are left over from construction projects etc. Remember if you use a house furnace you dont get a 30 degree to 75 temp tise as you generally would with a hanging furnace. but you must keep it at about 60 until you adjust it for the day. insulation is important and where I live a second meter is a commercial rate. My bill for gas and electric for a 24x28 is 100 to 150 depending on how much i weld. Works for me. No moisture in the shop an no rust
Old 11-11-2022, 03:21 PM
cnc's Avatar
cnc cnc is offline
Rest switch resolved the issue …..functions like it should..
The Following User Says Thank You to cnc For This Useful Post:
Old 11-11-2022, 05:27 PM
Shiny Shiny is online now
Glad you got it fixed!
What's a rest switch?
Old 11-13-2022, 09:15 PM
cnc's Avatar
cnc cnc is offline
Yep adjusted it and sorry it's the Limit switch it's a long bi metal tube with dis similar metals that control the fan function as well as the gas valve ..theres a guy on YouTube grayfurnace man great explanation of how it works ..if ya wanted to see....
Old 11-13-2022, 10:30 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Did the repair tech ck the heat exchanger integrity? A 40 yr old unit is likely cracked or rusted through. Here's a quick test, BUT NOT FOOL PROOF. With the main flame OFF, push in the white button on the fan/limit switch and the fan will start. Watch the pilot flame as the fan starts and if it begins to waver, the heat exchanger may be compromised, allowing carbon monoxide into the space! Pull the switch to stop the fan, now turn the tstat up and watch the main flame as the fan starts. Better yet, use a borescope to ck each bay.
Follow previous advice and replace it. Hang a unit heater with closed combustion that uses outside air for combustion. You will accomplish 2 major improvements, added floor space (which is golden) and removing the OPEN FLAME form the garage for safety. Plus, it may be more efficient.
Yes, I hear everyone out there saying a torch or sparks are an open flame. Would you light a torch or strike an arc if the space was full of flammable fumes? The furnace can't make that decision! Your life, your call! Except when your grandson is helping.
Old 11-14-2022, 07:36 AM
dataway's Avatar
dataway dataway is offline
Might want to put a new furnace on your to-do list. Maybe find a scratch and dent unit for sale. The right size modern high efficiency would probably pay for itself in a few years of use .. specially if you can install it yourself.
Modern high efficiency units can exhaust through a 3" PVC pipe and are very quiet.
Old 11-15-2022, 10:36 AM
JUDGE3 JUDGE3 is offline
radiant tube heat is awesome if you replace it.
checks all the boxs for a garage. outside air intake/exhaust/quiet/super efficient/no exposed flame or gas/no humidity returned to your garage.
