Old 10-09-2009, 11:48 AM
bankbook's Avatar
bankbook bankbook is offline
Default 535 CV 1 head Turbo build
I am in the process adding a turbo to my 79 Trans Am.
The motor is a 535 cube CV 1 Head with convertible exhaust.
I am doing all the fab work myself.
I do have a post on PZ but not all of you are there so I figured to post it here as well
A few pictures of the before.
ID:	183710   Click image for larger version
ID:	183711   Click image for larger version
ID:	183712   Click image for larger version
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 10-09-2009, 11:53 AM
bankbook's Avatar
Default heads
Here are a few pictures of the heads after coming back from the Race Shop in Wisconsin. They opened up the chambers and performed the Convetrible exhaust work.
ID:	183715   Click image for larger version
ID:	183716   Click image for larger version
ID:	183717   Click image for larger version
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 12:03 PM
bankbook's Avatar
A few pics of the turbo fabbed up in the car behind the bumper cover, in front of the radiator. There was a good amount of cutting that had to be done to fit this particular turbo.
The bracket will bolt to the chassis bumper bracket as well as to the bumper itself.
ID:	183719   Click image for larger version
ID:	183720   Click image for larger version
ID:	183721   Click image for larger version
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 12:50 PM
bankbook's Avatar
A picture of the pipe I started with , and the headers fabbed up.
ID:	183725   Click image for larger version
Name:	Drivers header1.jpg
ID:	183729   Click image for larger version
Name:	Drivers header3.jpg
ID:	183730   Click image for larger version
Name:	Drivers header2.jpg
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 01:00 PM
Looks fantastic!
Old 10-09-2009, 01:38 PM
triathlonx13's Avatar
Did you have to make any provisions for your steering shaft?
Very Nice !
What is that combo capable of HP/TQ?
Old 10-09-2009, 02:15 PM
bankbook's Avatar
The Covertible exhaust option on these CV 1 heads really makes the header fabrication quite easy. The only issue I had was on the #7 tube. I did have to use the magical hammer on the bend to give me that extra 3/8 I need to clear the upper steering knuckle. I am sure if I had more time I could have gotten it. Over the winter I will do it, as I need to be ready for Englishtown in two weeks.
As for the power, I am not sure, but I know I am well into the 1000+ range.
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 02:24 PM
What size turbo?
Inner cooled?
Old 10-09-2009, 02:25 PM
bankbook's Avatar
106mm
Meth injection
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 02:26 PM
David Holmberg's Avatar
Very nice, thanks for posting!
Keep us updated on this, a lot of people will be interested.
Old 10-09-2009, 02:34 PM
bankbook's Avatar
Thanks.
Here are a couple of the engine without the headers on.
ID:	183737   Click image for larger version
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 02:46 PM
azbirds's Avatar
azbirds azbirds is offline
Awsome build!! Keep us updated.
Old 10-09-2009, 03:04 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Looks awesome man! Can't wait to see it completed and what your track results are!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 10-09-2009, 05:37 PM
bankbook's Avatar
If your going to E town in two weeks Brian, You will see it.
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 08:03 PM
bankbook's Avatar
Here is a pic of the header. I will be re doing the one corner as the hammer massage was just a bit much. Looks worse than it is.
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 08:28 PM
bad69bird's Avatar
Yup...that's the plan! Are you bringing your car?
Old 10-09-2009, 08:38 PM
bankbook's Avatar
Thats my plan as well. It looks like the Chassis shop, updating my cage will have the final say. Thay are adding the halo, dash bars and a net. He says a week, but you know that story. They get it Monday.
I will be in the garage tommorow all day and part of Sunday getting most that I can done ao I will have only minimal stuff to do.
At minimum I want to make a few passes as a test and tune on the combination.
DOC'S TA
Both 4 speeds!
Old 10-09-2009, 10:30 PM
bad69bird's Avatar
Sweet!
500plus's Avatar
500plus 500plus is offline
Lookin real "GOOD"!! Congrats on the work and plan on having some fun!!
Old 10-10-2009, 12:25 PM
badassgoat's Avatar
badassgoat badassgoat is offline
Hey Doc, the bird is out of Chris's place as of yesterday (Friday) afternoon so you're up dude. The rear FW came out really nice. He does good work - in and out in 1 day.
