THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Up...lifting experience
Mike and I started assembling the car lift last night. and YES, I did help lift this monster. check out the percise space between the top of the beam and the ceiling. holy inch Batman get you some of that! Sorry it’s sideways I am stoked to get the cars up on this thing. had to share the progress.
"BIG DADDY" VIDEO http://www.youtube.com/watch?v=QnFIVLuwO9A ~MaryAnn~ AKA "Stickybuns" 1969 Firebird 400 Convertible 1978 Bandit T/A Tribute 1977 RED TA I'm the FiredUp PY bad girl |
So now the undersides of your cars will be as clean as the tops?
Yes Sir! That’s the plan plus a project that’s been on hold for way to long, the WS6 TA that my Daughter bought from Chris Cassperson, is not running, we need to get that on the lift and drop the motor so we can see what happened to it. 4 years ago.
A friend bought a 2002 Camaro. Had 65,000 miles on it, had 2 burned pistons...
Her’s sat over the Winter, like many do its not driven in the Winter she went to start it after checking the fluids and it started right up, ran for 2 minutes, and we herdsomething like when a dip stick rattles not being seated in the tube, or a catalytic converters rattle, then it shut itself off. Tried it again, started for 30 seconds and shut itself off. My Son sent a scope into the pan, and a magnet no metal in the oil. Mike thinks it has something to do with the compression stroke?so we will finally get it up on the lift and drop the motor and hope it’s not damaged. She is so bummed not to be able to drive it, I just hope it’s not the motor because that’s not gonna be a cheap fix being an LS motor.
Get it scanned to see if there are any codes in it. Could be anything. RPM sensor, cam sensor, knock sensor, low fuel pressure, etc, etc.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
Sounds like it may have lost oil pressure.
Nice. How high is the ceiling in there.
Mine is 13 feet in the center. Not the same design as yours though.
64 Lemans hardtop 4spd, buckets |
Been following the uplifting story. What an accomplishment!
72 Luxury Lemans nicely optioned |
13’6”
Thank you Joe, it’s so exciting knowing we are doing it pretty much ourselves and it’s almost there.
Thought the total height on hoist was only 12ft?
Benpak XPR10S? looks pretty close to ceiling.
It is VERY close!
You'll have to get the ladder out and measure a column for me. LOL.
Have not ordered mine yet and trusses are in so no going back on that. Have 13 ft ceiling.
Sure thing, I’ll ask Mike later today.
