For sale - Carter AFB 3649s cosmetically and mechanically restored.
Choke housing and pump jet housing have been rechromated. Steel linkages have been electroplated with white zinc. New jets, new step-up pistons, new step-up springs, correct step-up rods. All metal castings have correct casting numbers, venturi clusters have correct stamped numbers. Reproduction tag stamped L3 (November 1963) is correct color. The only fly in the ointment is the plastic choke cover is stamped 170AC478 and should be 170AD478. Spring is correct, but do not have the AD cover. Adjustment is correct. 47 state total with shipping and insurance is $700. (would have been 750 if I had the correct plastic cover). If shipped to a Missouri address, I have to charge sales tax. VISA or MasterCard. 573-392-7378 (9-12, 1-4 Mon-Tues central time) OR email username is carbqueen, ISP is sbcglobal, and the ISP is a dot net. I write the email in this fashion to confuse the robot/scammers. Please do not "help someone out" by writing it in normal format. Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
