#41
I think the OP is going to find that what he has lost on the bottom he will gain back at the top and run about the same overall but with a different attitude. |
#42
You gotta be kidding me. LOL If he has any chance of making this cam work with this combination or any other it sure wont be with a stock converter. I'm surprised it even idles |
#43
got some 1/4 mile data
1st run 13.89 at 101 with this cam.
Stock can ran a best of 13.9 at 97, but typically ran low 14s. So there is some improvement. I'm going to make another pass in prob an hour.so pucked up some mph. 60 foot was a horrible 2.37 hooking up with stick converter .
1968 pontiac lemans 400. 13.16@102/8.5:1 /6x-4/lunati bm 2 cam/ 3500 stall/3.55 gears. |
#44
Second run 13.72 at 101.49
#45
Nice. What was your 60 foot time on that run?
Stan
#46
A whopping 2.22. BTW my dads trans am 455 ran a 12.8@102 so I'm trapping the same mph as him. He's got a lot of torque though.
#47
Pretty respectable for a 8:5.1 400 with that cam! Congrats! Get a better convertor and some more gear and it will really pick the 60 up
#48
It will need a 10" converter , starting off decent I would say.. probably go low 13's with only converter
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
#49
Sounds good. That 228 single pattern in my TA ran decent for low compression 2.56s and barely hitting third in the 1/4. Didn't feel like I lot bottom end on it
#50
A good convert will knock .20 of your 60' times. A Hughes GM25 will work well for cheap.
#51
Can you elaborate any more on the 11:1 406 your are putting together??? iron heads? type? Alum heads? proposed octane gas to be used in it? Thanks Jeff
#52
We're using 1969 #46 heads upgraded with 2.11/1.77 valves and screw in studs. Heads will be milled for more compression, to effectively use a cam with 304/314 duration on a 113LSA. It will run fine on pump gas with correct tuning, 92-93 octane, as the RAIV clone doesn't make that much dynamic compression in a 400 build.....Cliff
The Following User Says Thank You to Cliff R For This Useful Post: | ||
#53
I used to run the comp 280 magnum cam in my 400, great cam.. but the motor had a set of 62s..with the 6xs I wouldn't know how that set up would act with the 280...
1970 firebird, 468, e heads, |
#54
Can different cam phasing help such a combination as this (much)???
#55
I think you could cut a few more tenth off with a 2800 stall. 20 years ago i had a 8.5 comp 400 with 6x heads,744 cam adv 2 degrees, HO alum intake and RA cast iron manifolds, it would run 13.40@ 104. With a stock conv it wouldn't run in the 13's.
#56
I checked compression they are all around 125 except I have #2 cylinder at 100 psi.
#57
What kind of car this build going in??? (weight?) Gear ratio? Anything special about the ICL??? Valve spring specs??? I assume this can be a 6500 RPM engine??? Rhoads lifters??? Thanks as always... Jeff
#58
Update, installed stall converter
It now idles better and accelerated better. Took it to the track and it took me down to a 13.25.
#59
Sweet! nicely done! great job working through it!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
#60
Nice. Glad your friends converter worked out for you.
