First build post in almost a decade, here is my 490 street engine
It’s been a long time since I frequented the PY forum but 2 back surgeries a busy shop and 5 kids has that effect but thought I’d share my personal 490 I’m building for my 1973 luxury lemans, normally id be posting a customer engine so this will be different lol
This is based on the original engine except for the intake manifold, car will mainly be a street deal so I can play a bit, its a flat tappet but everything is set up to be roller with a couple changes when i can afford it. Im using the original TH400 trans, 2600 stall, 3.08 and 2.41 posi 10 bolt, 275-60-15 ET streets 1973-400 2 bolt with ARP studs, oil passages radius’d 4.165” bore, -.002 deck height, .0025 rods and main clearance SGI 4340 4.50” stroke crankshaft, 6.700” scat pro comp I-beam rods, UEM 4.3cc flat top pistons 9.88:1 compression, 3/4 groove main bearings, king rods, clevitte cam bearings Modified and blueprinted M54DS oil pump, butler pro plate, Canton Road Race Pan, modified tomahawk tray and crank scraper 9-keyway summit timing set, Pro Products balancer Crower 60919 camshaft degreed to 113* ILC Crower Cam saver lifters, Smith Brothers 5/16 .083 wall 9.225” pushrods 1973 4X3 heads CNC ported back when SD did Iron heads, then hand blended with chamber work by me, flowed before and after hand work, 260cfm before and 273in 222ex at .600 after, i got them with no finish work done back in the day to save, pick whatever numbers you believe, heads turned out very nice They are using Ferrea 5000 series SS 2.11in 1.77ex valves 30* back cut on intakes, Comps new 26995 Beehive springs designed for hydraulic flat tappet cams in pontiacs and olds, Comp retainers, 10* locks, Spring seats, ARP rocker studs And poly locks, Melling 1.65” stamped rocker arms Fully ported 72 iron intake, I have a couple ive ported and modified to test with including One that is 80% burr finish and 60 grit in the transitions 17056263 apt style 850 Q-jet i build using Cliffs parts exclusively, Factory distributor with Pertronix 3 with rev limiter, i may instead go with HEI I don’t know yet Cheap long tube headers, id like to get a set of OS RARE manifolds i can port and use but they are hard to come by now I should be done with the build in the next 3-4 months assuming I can get it on the dyno, I don’t expect a ton of HP with the cam im using but it still should be fun either way!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
The Following User Says Thank You to Pontiac Derek For This Useful Post: | ||
More pictures
More pictures
Really cool build and impressive set of heads. I'm interested in the results.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Nice build Derek. Looks great! Well thought out with a lot of attention towards detail. I bet it a delivers!
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Very cool
Looks good, been following the build on Facebook....I still run my Torker 2 that you did plenum work on!
Thank you!
Thank you! Much appreciated! I hope you are well!
Thank you! Yeah your setup is still very impressive!
Thanks for sharing
John L Sent from my SM-X200 using Tapatalk
The Following User Says Thank You to OZZIEVILLE 67 2 door For This Useful Post: | ||
I love it! Nice work, I would like to do similar. Tire burner for sure.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
Thank you yeah I have no doubt it will have no trouble smoking the tires until I let off the throttle! And it still has AC, the older I get the less I want something that is extremely rowdy for my street car
