Old 06-26-2021, 09:00 AM
Hotrodjohn71 Hotrodjohn71 is offline
Default 67 Firebird door window height adjustment
Hi group. I need to adjust the drivers door window height stop down about 3/8".
What are the exact adjustment points to only make the window stop a little lower.
I dont want to knock any other adjustments out of whack.
Thank you
Old 06-26-2021, 08:15 PM
Sport69 Sport69 is offline
These are your front and rear height stops, loosen them and adjust them up or down to get the correct height. After any adjustments make sure to close your door "slowly" to check for correct adjustment.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
The Following User Says Thank You to Sport69 For This Useful Post:
