Engine IN frame engine mount change
How difficult is an in-frame engine mount change?
No body on the car ... just chassis with the engine in ... before I drop the body on I think I might want to change from the crappy parts store mounts to the new correct mounts from Ames. Engine is hooked up and running, log exhaust ... wondering if I can get in there and change them without hoisting the engine up. Could bring the hoist over and lift/support the side of the engine I was working on easy enough. |
easy squeezy
use the lift drop the starter you need to put the starter strap on anyways dont forget blocks to lay the starter on |
The Following User Says Thank You to Scott Thelander For This Useful Post: | ||
Are those Torq Loc a good mount from Ames? Im changing my motor and the original mounts seemed sacked out. Thanks
Scott ... hey, no amateur here, I've got a starter strap installed
No need to remove the exhaust manifold or down pipe? Pipe would be easy enough. I was looking at the Torq Loc, but since this is a stock build figure the new "standard" mount that Ames is selling that has the correct gauge metal and such would be enough. |
