Old 06-19-2021, 05:06 PM
Formulabruce's Avatar
Default 1970 12 bolt axle tube welds
About to rebuild a buddy's 1970 12 bolt from his Formula.
Had a leak all its life so its amazingly clean. Take a look at the leak. Think I should MiG weld this all up, brass, or ? Have tiny holes at edges before, but not this.
ID:	568472   Click image for larger version
Old 06-19-2021, 11:25 PM
rohrt rohrt is offline
I had my 8.5 tubes welded. After researching it it made sense to me to have it done professionally. The cast center and steel tubes need to be welded with a nickle rod. There is a high chance of warpage so a fixture should be used. I think your suppose to pre-heat everything and a slow cool down process.
Old 06-23-2021, 08:27 AM
gtospieg gtospieg is offline
I had an 8.2 with a leak in the same place...cleaned it up real good and used black silicone...never leaked again.
Old 06-23-2021, 10:22 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Jay Bee Well Duh
J/K but it will work though.
If they are gonna drag race it then the welding with nickel needs to be the whole circumference of the tube to the iron carrier where it transitions on each side since on leaf cars hooking with traction bars sometimes the who center breaks loose and pivots the snout up on the launch
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
Old 06-26-2021, 06:51 PM
Worked for Pontiac when those cars were new. Saw several with bad welds at the axle tubes. They actually turned the tubes in the center housings. I would recommend getting the whole thing welded professionally
Old 06-26-2021, 07:07 PM
TY all for your input! No racing, just drive to cruise nights
Thread Tools
Display Modes
