Old 06-21-2021, 10:45 AM
461-69bird's Avatar
461-69bird 461-69bird is offline
Question 12v ign source
Where can I tap into an ignition source for after market extras? I did have them connected to a spade fitting in the fuse box under the dash but it's stopped working, no power there. I've had to connect to another one next to it but it's not on the ignition just live.
69 Firebird
69 Firebird
472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123
Old 06-21-2021, 12:11 PM
padgett's Avatar
padgett padgett is offline
Cigarette lighter circuit is usually 20A. Do you need it to be switched ?
Web Site
Old 06-21-2021, 04:37 PM
461-69bird's Avatar
I don`t have one of those
69 Firebird
Old 06-22-2021, 03:07 AM
Use a relay to power a terminal for all your extras that you want to run off an ignition circuit. You can feed the power side off the battery and the trigger side off any ignition source including the positive side of the coil. The amount of amperage to trigger the relay is so low it will have no effect on your source.
Old 06-22-2021, 12:01 PM
461-69bird's Avatar
Thanks. Can I feed a fuse box that then feeds my extras this way?
69 Firebird
Old 06-22-2021, 12:22 PM
Scott65's Avatar
Scott65 Scott65 is offline
I feed a 12 circuit fuse box via an 80 amp relay in mine. Triggered by key on and cranking powered source. It's off when the key is off. I use a fusible link and battery power for the load side of the relay.
Old 06-22-2021, 01:34 PM
461-69bird's Avatar
Ok Scott thank you
69 Firebird
Old 06-22-2021, 04:13 PM
Kenth's Avatar
Kenth Kenth is offline
69 Firebird
No power at that spade may be a blown fuse.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-22-2021, 10:55 PM
killakev's Avatar
killakev killakev is offline
Exactly - I would look to see why the my previous connection isn't working anymore....
