Old 06-26-2021, 03:40 AM
dataway's Avatar
dataway dataway is offline
Default What is the no holds barred best body filler?
Not including lead of course.
Evercoat?
Bondo (3M)
Etc.
Price is not really a factor, I'll probably only need a quart for the whole car... I hope.
Old 06-26-2021, 08:26 AM
dhutton dhutton is offline
Evercoat Rage Ultra sands great imho.
Don
The Following User Says Thank You to dhutton For This Useful Post:
Old 06-26-2021, 08:38 AM
mrennie's Avatar
mrennie mrennie is offline
I researched this extensively before I started my bodywork, and there were so many opinions it was hard to develop a clear answer before choosing one.
I used Rage Gold for most of my car, it was the first "premium" filler I had ever tried compared to the cheap crap I used on previous projects, and it was definitely easier to sand so I liked it.
I have since tried 3M Platinum (not Platinum Plus), and it was noticeably easier to sand, less pinholes, and between the two I would use it again as my first choice.
I realize there are many options for premium filler and many I have not tried, so others with more experience will have better insight.
One thing to be aware of is that many of the higher end fillers are only available in gallon cans...not sure why, but sucks for us hobbiests as I would have bought quarts of several kinds to see what was best.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
The Following User Says Thank You to mrennie For This Useful Post:
Old 06-26-2021, 11:17 AM
400 4spd.'s Avatar
We use 3M Platinum, have been for years. I don't care for the Platinum Plus either. I switched from Rage because it would "chunk up" before the gallon was used up. Whatever you use, keep it sealed when not being used.
The Following User Says Thank You to 400 4spd. For This Useful Post:
Old 06-26-2021, 02:50 PM
72projectbird's Avatar
I've always used Rage Gold, and have had great results. Its easy to work with and sands easy.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 06-26-2021, 05:01 PM
dataway's Avatar
Excellent, thank you for the recommendations.
Gallon is fine, I use it for various other things around the compound, great as a wood filler, sheet rock repair etc.
Old 06-26-2021, 06:51 PM
Formulabruce's Avatar
I now use a German made "cream" that is ultra light and sands like the Platinum. It comes in an accordion squeeze bottle.
This is as close to sprayable as you can get. Ill get the name soon for ya.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 06-26-2021, 08:33 PM
nytrainer's Avatar
I use Rage but not really tied to one brand. What I do always have on hand is Evercoat Plastik Honey which I can add to filler when I’m skim coating a large panel or when the gallon of filler gets a little thick.
The Following User Says Thank You to nytrainer For This Useful Post:
Old 06-26-2021, 09:03 PM
grandam1979 grandam1979 is offline
I have always used duraglass as base coat of filler hard to sand but worth it.
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 06-26-2021, 11:39 PM
MUSLCAH MUSLCAH is offline
Snowball….and Nitro Stan…..Iam old school………
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 06-26-2021, 11:48 PM
I don’t like to give out my secrets…it just keeps me a step ahead of the competition….you know,like a good meatball recipe !
Old 06-27-2021, 12:00 AM
einstein's Avatar
einstein einstein is offline
No idea what snowball is, but in 1970 Dad used Nitro-Stan on a '29 A Roadster. One trick was thinning it and putting it in the spray gun to create a high-build leveler over his lead work.
Old 06-27-2021, 09:25 AM
I still have some Nitro-Stan.. Nitro Cellulose wrinkle maker.
I doubt there is much that can shrivel up like this stuff. Its not for anything except scratches on old lacquer. This is one reason why I like "improvement!
Old 06-27-2021, 09:34 AM
AKA….”Red Lead “
Old 06-27-2021, 12:58 PM
jww jww is offline
Smile
I like 3M Platinum in gallon can. Goes on smooth, sands easily, some pinholes but I think all fillers will do that at times. Be aware, just cause it comes in a gallon can doesn’t mean u get a full gallon. More like 80% of a gallon. Don’t know why 3M does that??
I guess it like potato chip bags get smaller and smaller but price remains the same! and ice cream too.
Have a good Sunday all
Old 06-27-2021, 02:22 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Use Fusion by US Chemical. Sands very easy , no pinholes and has additives to prevent rust.
Old 06-27-2021, 06:55 PM
Don’t say I Nevah gave you anything. It’s sands like Sheetrock spackle…The first cut is done with 80 grit…..so don’t buy anymore 40 grit paper. You’ll thank me later. Iam sure Don hates it…..lol
Old 06-27-2021, 08:36 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I use that when I can get it, it's great stuff.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 06-28-2021, 01:11 AM
dataway's Avatar
Is the Evercoat "Edge" even made anymore? It's not listed on the Evercoat website, or is it just Evercoat "Premium" with the "Edge" added because that's the Evercoat trademark?
I bought a gallon of 3M Platinum to give that a try. Any modern filler is going to better that what I was used to 40 years ago, needed a cheese grater to sand it, always seemed a bit tacky or gummy unless it dried for days.
Old 06-28-2021, 07:43 AM
Isn’t that just Rage Ultra with a different label for “professional” use? I’m pretty sure it is….
I love that stuff….
Don
