Old 07-01-2021, 10:55 PM
nytrainer's Avatar
Default Intake manifold 9794284?
Looked on a few Pontiac related sites to check this intake #. Appears there is a 97942”3”4 listed. Is there a 97942”8”4 or am I just seeing it wrong? Whiich is correct for a ‘68 350HO? I have a 9790140 on it which I believe is original because it’s a numbers matching drivetrain. It a Arlington build.
Old 07-02-2021, 12:02 AM
gto4evr gto4evr is offline
The 140's were early production 68 intakes before they switched. like made in late 67. I can't remember the change over date offhand. what's the date code on it and the build date of your car?
Old 07-02-2021, 04:32 AM
Kenth's Avatar
Kenth Kenth is offline
9794234 first appeared at the introduction of the RamAir II engine mid-may 1968 on all Pontiac V8´s and were also used on all 1969 engines except RAIV.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-02-2021, 09:27 AM
OG68 OG68 is online now
In my search for a replacement date correct intake I noticed the 140 to 234 change over casting date was approximately March 16 or 17 of 68.
The original cracked '234' manifold was dated D108. I luckily found an excellent D118 replacement. My 68 is a 05A build with a WT engine.
2007 Cadillac SRX
Old 07-02-2021, 06:16 PM
Half-Inch Stud's Avatar
Amazes me that the 0140, 4234, 068 manifolds were designed "just right" for 350 thru 455.
Old 07-02-2021, 09:58 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Agreed, a masterpiece of performance while keeping in tune with diversity.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
