Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Th400 9.5" Torque Converter, Headers, Rods Pistons, SS Fuel Line, Fittings MORE!!
9.5" Torque Converter, 3600 Footbrake Stall on 450tq engine, $300
Stainless Braided fuel lines, came off my GTO with Ricks Hot Rod Tank, 12an, 10an, 8an with fittings. Easy over $600 invested, $200 (fittings are really the prize) Factory Rods and Forged Speed Pro Pistons .030 over. $150 Factory Boxed Control Arms with poly bushings = $100 Flat Tappet Cam, 288/292, 108 LS with lifters = $80 Headman Headers, coated, D Port, 1 5/8 = $75 K&N Air Cleaner, 4"x14", for 4150, maybe 500 miles on it = $50
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump Last edited by GOAT8U2; 07-05-2021 at 11:40 PM. |
More pics
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
Pictures
More Pictures
Cam pics
Rods, Pistons
More pics upon request.
Im interested in the rod, piston combo.
I’m interested in the fuel lines and stuff. Can you call or text me ? 859-360-8421
Rods pistons = SOLD
K & N X Stream air cleaner is $165 new, $50
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump Last edited by GOAT8U2; 07-23-2021 at 09:07 AM. |
I’m interested in the air cleaner can you give me shipping cost to Ohio 45889? Thanks
K N filter = SOLD
