Old 07-14-2021, 03:10 PM
arbys's Avatar
arbys arbys is offline
Default Removing brake rod from pedal
Is there a trick to removing the rod from the brake pedal on my 66 LeMans? The new dual m/c requires a shorter rod so I would like to remove and shorten the rod. 4 wheel drum brakes.
Old 07-14-2021, 04:28 PM
Jeff Hamlin's Avatar
You have to remove the clip off of the Clevis Pin remove the pin and then un-thread the Clevis off the rod.
Then you can unbolt and remove the MC to remove the rod for alteration.
Name:	66 AT BRAKE PED 1.JPG
ID:	569744   Click image for larger version
Name:	66 AT BRAKE PED 2.JPG
