Old 07-20-2021, 03:02 AM
Formulabruce's Avatar
Default Port injection on a Performer
Has anyone had a Performer intake milled and drilled for port injectors?
Just curious as I think all the single plane intakes that come ready are to high for a STOCK Shaker or Formula hood ( 70-75 ).
Looking for efficiency on all cylinders, low end TQ, all in at 2400,
and fuel economy.
I can, and have done this with a carb, but curious if Its possible to get the engine to run cleaner, or more even on all cylinders.
Thanks, FB.
Old 07-20-2021, 06:33 AM
Scott65's Avatar
Scott65 Scott65 is offline
I don't have the answer to your original question. But its worth mentioning that the Torker 2 version of Edelbrocks port efi manifold (called a Victor efi I believe) may fit with the shaker as dry throttle bodies are significantly shorter than carbs.
Old 07-20-2021, 07:19 AM
max 93 max 93 is offline
I am in the process of installing the Pro Flo 4 and the height is the same as the factory intake and q jet
Old 07-20-2021, 07:53 AM
Scott65's Avatar
I think you could probably have a good running engine with the Performer. One thing to keep in mind is injector rail height. That could possibly impact using the shaker air cleaner assembly? The Victor efi uses shorter injectors and lays them over at a slight angle, making the rail height less of an obstruction. I think the different height ports of the dual plane would prevent using that method. Let us know if you try it, and what the results are.
Old 07-20-2021, 09:21 AM
Steve C. Steve C. is online now
Consider a Tomahawk manifold that it the same height as a factory intake. Injector pads cast in.
https://butlerperformance.com/i-2445...tegory:1234847
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 07-20-2021, 10:27 AM
Side note, I linked Butler info for the Tomahawk only because there was a picture available on his website. Keep in mind there are other sources, example I buy parts from Paul Knippen on occasions. He has very good prices.
Old 07-20-2021, 01:12 PM
Tom Vaught's Avatar
Boost Engineer
The Tomahawk intake with the flow improving mods BEFORE they were cast up were some
really nice intakes for flow and distribution as well as a lower height.
A very good intake for a water to air inter-cooler inside a old Vortech pressure box.
Tom V.
Old 07-20-2021, 01:13 PM
ta man ta man is offline
I would use a Torker 2. I'm not an engineer but I like the more even length runners.
Old 07-20-2021, 02:44 PM
Formulas Formulas is offline
Not to mention drilling and welding in bungs for a injector will be a piece of work due to different approache Angle's at the intake / head interface
Just a load of extra work and engineering with no hope of outdoing a tomahawk or T2
The Following User Says Thank You to Formulas For This Useful Post:
Old 07-20-2021, 04:34 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The EFI Torker II has an angle on the injectors requiring shorter PICO injectors or the fuel rails hit the plenum.
Skip Fix
Old 07-20-2021, 08:10 PM
tom s tom s is offline
What about the Holley SD single plane,stock height.Tom
Old 07-20-2021, 08:17 PM
Doesn’t the Performer mount the carb at a different angle as compared to a stock intake?
Pretty sure the shaker scoop will not look right or seal against the hood correctly with the Performer.
Old 07-20-2021, 08:38 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by Formulas View Post
Not to mention drilling and welding in bungs for a injector will be a piece of work due to different approache Angle's at the intake / head interface. Just a load of extra work and engineering with no hope of outdoing a tomahawk or T2
We did a lot of work on Injector Placement and angle in the runner at one time and after a 3 year study with a bunch of dyno testing, there was a slight improvement, in Emissions depending on the swirl and tumble designed into the head.
With the hot rod stuff we found you could put the injector at basically any angle (even upward) and it made minimal difference in power which is why people "stack injectors" (one above the other) as the flow of the upper one just adds more fuel to the mix under power. At Low speeds the lower injectors if sized correctly let the engine run cleaner when not at full power and boost. The average intake manifold injector placement would make little difference in power and it is better to have a clean fuel rail design feeding the injectors vs being too close to a heat source.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 07-20-2021, 09:00 PM
Gary H's Avatar
Gary H Gary H is offline
Look at the Speedmaster intakes. They offer a single plane intake with bungs already in place. It says right on their web site that it is the correct height to run a shaker air cleaner
The Following User Says Thank You to Gary H For This Useful Post:
Old 07-20-2021, 10:20 PM
amcmike's Avatar
amcmike amcmike is offline
LS3 injectors would work as well.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 07-21-2021, 07:57 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
I made my Torker II eif back in '08. That takes a minute....lol back then there were no "off the shelf" injector ready things for PONCHO's. So consider its NOT just the intake but the fuel rails and some kind of retention. The PICO injectors are a godsend as the TALL ones would be a nightmare for interference when mounted VERTICAL.
MOST all throttle bodies are THE SAME height as a carb.
There are MANY ways around intake height and a SHAKER...
Old 07-21-2021, 08:26 AM
Scott65's Avatar
That's simply untrue about most all throttle bodies being the same height as a carb.... Perhaps it would be true of those with injectors in them. But since the OP is talking about port injection he doesn't need one of those.
Old 07-21-2021, 09:26 AM
As noted it's this type of throttle body. I used this Holley unit as an example:
https://www.holley.com/products/engi.../parts/112-577
Also note on some the 4500 style are shorter than the 4150 style
Old 07-21-2021, 09:39 AM
Scott65's Avatar
https://www.jegs.com/i/FAST/244/3076...hoCI5cQAvD_BwE
FAST, reduced height
Old 07-21-2021, 12:16 PM
Tom Vaught's Avatar
Boost Engineer
Example of a Victor EFI and Billet Throttle Body with ability to fit under a typical hood but then you need to start looking at Shaker Air Cleaner height vs top of distributor cap wiring.
Tom V.
Name:	Victor EFI and T-B.jpg
