Old 11-24-2010, 05:07 PM
Groucho's Avatar
Groucho Groucho is offline
Default WANTED-1965 Catalina left lower front control arm, A-Arm
I'm told 65-70 BIG car's the same. Thanks
Big Willie and Tomika's Street Racers
STUGOTS-SoCal
Adding more power since 1971
Old 11-24-2010, 05:08 PM
Late 65 [second design] to 70 interchange.
former." --Albert Einstein
- Winston Churchill
Old 11-24-2010, 06:54 PM
Groucho's Avatar
On the LOWER arm, what's the dif between the 2 designs? Thank you
STUGOTS-SoCal
Old 11-24-2010, 07:25 PM
mechanickeith's Avatar
steve@pontiacheaven.org
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 11-24-2010, 07:38 PM
1st design has a plate welded over the balljoint area. These were replaced in a service bulletin with the 66 up units.
- Winston Churchill
Old 11-24-2010, 07:41 PM
Groucho's Avatar
Oh yeah, I saw that in an earlier than 65 Pontiac yrs ago! What a bitch changing ball joints. But, I do remember doing it. Thank you
STUGOTS-SoCal
Old 11-25-2010, 01:45 AM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
I'm parting a 65 Star Chief, it was determined that it is a second design. Need one or pair, need uppers at all? let me know.
Old 11-25-2010, 10:19 AM
Groucho's Avatar
I need one lower (left) for sure. Someone welded both bushing sleeves to it. The other appears OK, but I'll look closer. One upper (left also) is a little beat up. My questions are, how "clean" are yours and how much? BTW, what's a 65 Star Chief look like? Thank you
STUGOTS-SoCal
Old 11-25-2010, 03:54 PM
65WJ's Avatar
65WJ 65WJ is offline
http://www.cars-on-line.com/42805.html
Poor mans Bonneville.
patrick
Old 11-25-2010, 05:30 PM
Groucho's Avatar
patrick
Thanks. I didn't know the Star Chief went past the 1960 year model. And the only Star Chief in 1960 that I've ever saw was a 4 door, or a post model, where as the Star Chief was attached to more deluxe/fancier equipped cars before 1960
STUGOTS-SoCal
Old 11-27-2010, 12:23 AM
Groucho's Avatar
I need one lower (left) for sure. Someone welded both bushing sleeves to it. The other appears OK, but I'll look closer. One upper (left also) is a little beat up. My questions are, how "clean" are yours and how much? Thank you
STUGOTS-SoCal
Old 11-29-2010, 10:25 AM
Groucho's Avatar
PM SENT!
STUGOTS-SoCal
Old 11-29-2010, 03:06 PM
Racer81x's Avatar
Racer81x Racer81x is offline
If Keith can't help you out I think I might have some off in one of my sheds, i'd have to take a look.
Old 11-29-2010, 05:43 PM
Groucho's Avatar
If you look, I think I'll need both lowers and the driver's upper. If you find them, please see if there's witness marks of prior bushing change, as an amateur attempt can ruin the bushing holes. Thank you
STUGOTS-SoCal
Old 11-30-2010, 02:52 AM
Got the message will check them out tomorrow. (Wasn't watching the thread...DOH!!)
Might as well sell the set of 4, can blast them too if you like, if weather permits.
KV
Old 11-30-2010, 10:32 AM
Groucho's Avatar
KV
Sure, all 4 might be a good idea. PM me with price. Blasting will be appreciated! I'm at 91352 for shipping. Thanks again
STUGOTS-SoCal
Old 12-02-2010, 03:02 PM
Groucho's Avatar
PM sent
STUGOTS-SoCal
Old 12-04-2010, 07:11 AM
aldbeir aldbeir is offline
i have disc brakes off a 69 cat i would like $250 for.
Old 12-04-2010, 11:09 AM
Steve Barcak's Avatar
The Star Chief was released as a top of the line model in 1954 ad remained ther until the Bonneville came out in '57. From '57 to '66 it remained the second highest model in the Pontiac line up. Was superceeded by the Executive.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 12-06-2010, 03:23 PM
Racer81x's Avatar
PM with pics sent
