1970 gto doors
Hi all. I need a set of door skins for a 70 gto. I cannot find a place that sells them. Any input on a vendor to locate these would be appreciated. I am also not opposed to full replacement doors. Mine structures are fine,
And have been blasted but boy the outer skins took a beating. I would also buy oem doors from someone as well if anybody has some that i can drive and pick up. Also 70 doors are one year only fitment? Is this true? Thanks
1970 Formula 400 4 speed 2006 Gto. Ls2/m6 1972 Gto 455ho/th400 post coupe 1973 Grand Am 400 4 speed |
70-72 doors are the same. Only difference is the placement of the side mirror . The 70 door is one year Only as the 71 and 72 doors the moved the mirror location towards the back a few inches. You'll have to find a oem or patch the holes on a 71,72 door and make new holes for a 70 look.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Thanks for that tidbit of info. Any idea on skins or doors? Thanks
No one makes skins or reproduction doors that I am aware of.
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
Years ago someone used to list lower door patches. I think the reviews were bad fitment. OEM doors do pop up, just need to be local to you.
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
Was '70 the first year for the side door beams ?
In 1970, the National Highway Traffic Safety Administration issued Federal motor Vehicle Safety Standard 214, which incorporated the static test and required all passenger cars to achieve certain minimum scores on the test, effective January 1, 1973. Beams were installed in all makes and models of cars sold in the United States since the effective date; beams were installed in many models up to 4 years before the effective date.
However, my 69 LeMans has them in the doors. Ironically the first year for a VW Beetle to have them is 1965. |
Thread Tools | |
Display Modes | |
