Old 05-29-2021, 01:56 AM
Bermudagto's Avatar
Bermudagto Bermudagto is offline
Default WTB 1971-2 455HO complete motor or HO coded block
Looking for ideally a standard bore block to build up.
1971 - WC/WL/YE
1972- WD/WM/YB/YE
1973-4 SD - W8/Y8/XD/ZJ block.
Old 05-29-2021, 08:23 PM
colerami14 colerami14 is offline
1971 - WC/WL/YE
1972- WD/WM/YB/YE
Hey buddy I know of someone who has a HO coded block in excellent condition send him a private message if you still interested in buying
Old 05-29-2021, 10:06 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
Looks like a scam to me.
Old 05-29-2021, 10:40 PM
Bermudagto's Avatar
Ok Thanks
Old 05-29-2021, 11:02 PM
Banned.
Old 05-30-2021, 08:13 PM
Good catch
Old 05-30-2021, 10:34 PM
poncho-mike poncho-mike is online now
You're going to be hard pressed to find a complete motor, and it will be quite expensive. If you're after a 4-bolt main block, you can add the 1970 XF (Grand Prix) 455 to the mix. It doesn't have round port heads, but those can be found separately. A complete SD motor is going to be north of $12K or more, and a 71-72 will set you back $6K or more, depending on how much is there. What is your budget?
Old 05-31-2021, 09:51 PM
Bermudagto's Avatar
Whew. Thanks for the market comps!
Old 05-31-2021, 09:54 PM
Bermudagto's Avatar
Banned.
Yep it WAS a scam
Old 06-01-2021, 04:10 AM
LATRLL1's Avatar
LATRLL1 LATRLL1 is offline
I do have a 72 YB 455 HO short block for sale ( 60 over in the car ).....I also have several 455 4 bolts for sale as well...these blocks are cleaned and magged and ready for a build..
.As poncho-mike was saying...these are not cheap...if your restoring a car and need a specific block - that's good
if you doing a race car or non-matching numbers car - a Butler strocker kit might be the way to go
Old 06-01-2021, 04:23 AM
Bermudagto's Avatar
Ok thanks. I’m thinking It may be best that I look at a 428 setup for my ‘69 anyway.
Old 06-01-2021, 09:37 AM
You can turn a 428 into a 455 by grinding a little bit of the bottom of the bores away (for clearance for the rods) and using a 455 crank. A 428 standard bore block can be bored .030" to make it a 455 standard bore if you use the 455 crank. That is the cheapest way to get a 455 4-bolt main bottom end.
Round port heads and the matching intakes are very expensive. The strongest street motor I ever ran was a .030" over 455 4-bolt block (this makes a .060" over 428) with a 428 crank (for roughly 440 cubic inches) with a set of 1970 Ram IV heads, Hooker headers, and a MSD system in a 1970 Trans Am. I used the factory Ram IV intake but deleted the crossover.
Old 06-01-2021, 11:12 AM
Where is Richardson? What part of the world?
Wouldn't want to have something shipped cross country if you could pick it up local.
Clay
Old 06-01-2021, 12:17 PM
Bermudagto's Avatar
I live near Campbell and 75. Do you live around here?
Old 06-01-2021, 12:32 PM
I'm in LaFayette GA, it's just a little ways south of Chattanooga TN
Clay
Where's Campbell?
