63 GP throttle linkage?
is there a bracket that the side towards the passenger side of the linkage goes into to keep it in position on the outside of the firewall or block? thanks
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
From Parts book
I think the plate/bracket bolts on 2 stud bolts on the left rear of the intake manifold. I have one for a 65-66 car but it's different, although similar. Do you need that part?
Here are two pictures of the bracket. It is the same regardless of trans and bolts on with the rear two driver's side intake bolts as mgarblik said.. It is the bracket pfilean's pictured in his post.
thanks guys. i'll have to look through the parts that came with the car to see if it is around. i have a wenzler gutsram that is on the engine. getting ready to put in shortly.
i took out the factory bell crank on n 62 catalina i just did put a Lokar pedal and cable on it
much safer setup
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
A cable set-up may be safer and much simpler in a modified situation. The factory linkage those years have allot of rods, bind and pinch points. Unless using solid engine mounts or some kind of restraint, I would be concerned about binding or throttle sticking in a high HP engine on rubber mounts. Good luck with it.
looked through what came with car and i don't see it. if anybody has an extra i could buy please let me know. i'll post in parts wanted later. thanks
