535 Engine of the week
The Following User Says Thank You to PONTYRAT1 For This Useful Post: | ||
Nice power level. Not record setting but 1050 is a lot of HP.
Criteria for this build was Bracket racing,We sizes the induction tract to make peak HP at 7200RPMs keeping the usable power curve at or under 8000RPMs. Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
The Following 2 Users Say Thank You to cfmcnc For This Useful Post: | ||
Cool!
Nice!
Very Nice build
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
So what part/piece of the engine is actually factory Pontiac?
Timing cover, distributor hold down, bore spacing, valve cover gaskets.
What does that matter? It's a race engine...
The Following User Says Thank You to Vengeance Race Engines For This Useful Post: | ||
I’m thinking that no matter what brand of engine you chose to run, when you get over 1000 HP, you’re pretty much all aftermarket parts.
This is the race section right?
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post: | ||
So why not just go with a big inch Hemi and make custom billet aluminum valve covers with the name PONTIAC on them? Kinda like when Pontiac no longer made its own engines and used big block Chevies with Pro Stock "Pontiac" 427 heads. Remember those? That wasn't a Pontiac engine either, but some will say it was because the valve covers had "Pontiac" cast on them - same as my Hemi idea, and probably a much stronger running engine seeing it's a race engine.
No offense, but your analogies are way off base and don't apply to the topic. |
The Pontiac engine certainly has its limits and can only be competitive to a point - this was learned back in the late 1960's/early 1970's when some Pontiac racers were installing Hemi engines in an effort to be competitive AND keep up with the Hemi dominated field. When you take something like an engine and completely redesign the block from top to bottom and simply retain those identifying features common to a factory Pontiac engine such as head bolt, oil pan, and timing cover placement, and then add a never available factory top end - well, the engine has steered so far from a factory piece that it is really not a Pontiac engine anymore than the drag racers who inserted Hemi engines in their Pontiac funny cars. So why not simply follow the earlier racers who were unable to compete using a true Pontiac engine and went Hemi? Just carve out some Pontiac specific valve covers as the Pro Stock guys did in early 2000 and slapped them on 427 Chevy big block engines and convinced themselves and the racing community that they weren't Chevy engines, they were Pontiac engines because the name on the valve cover said so. Pontiac logo valve covers on an 811 cubic inch Hemi would be a better competitor, maybe even cheaper to build, and I am sure the racing community could be convinced that no, it's not a Chrysler Hemi, but a Pontiac Hemi because the valve covers say so. With the broad acceptance of the LS engine in a Pontiac as if it was made that way, I think the Pontiac Hemi should be a consideration.......and a track competitor/winner among the real racers who actually win. Might give them a run for their money. |
nice piece for sure. interesting comments about wet decking hiding in there
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
The Following User Says Thank You to mysticmissle For This Useful Post: | ||
I wonder what it is going into?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Did he mention cam lsa??
117 is correct.We have other Pontiac cams done at 118-120 per application.Just for info current NHRA Pro-Stocks at 119.5-120LSA.Bill C.
The engine you built for this customer is similar to the one I have compression and horsepower wise. In my case we went with a 114 LSA, I may try something a little wider the next time around.
