Old 01-24-2005, 01:31 AM
JonnyP JonnyP is offline
I see in a couple catalogs and the GTO Restoration Guide that Pontiac offered a "Frame-to-Body Mount Bushing Supplement", which appears to be two additional bushings (one upper/lower set for each side of the car) which supplement the 14 that are standard + core support mounts. The OPG catalog says: "Some GTO, Tempest, and Le Mans were originally equipped with additional bushings depending on added options and engines size. Most vehicles with larger engines require this supplement." It also says: "The hardware (bolts, washers, nuts, etc.) are optional". I have a 400 out of a '67 GTO in my '64 so I probably can use these - Does anybody know where they should be located? I've seen post where people who replaced thier mounts found some that had no bolts, just the rubber biscuits, and I'm guessing these were "supplemental bushings" w/o the optional; hardware....? Appreciate advice - Jon
Old 01-24-2005, 04:28 AM
lil64gto lil64gto is offline
JonnyP
I don't recall seeing any 'extra' bushing holes on my frame when I did my frame off. There has to be a hole so that the bushings can be held.
Old 01-24-2005, 07:53 AM
Half-Inch Stud's Avatar
Sounds to me like the hockey-puck bushings...no bolt.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 01-26-2005, 07:21 AM
pugslyx234 pugslyx234 is offline
On my 68 conv it has 2 one on each side above the rear axle on the frame to support the body no bolts
Old 01-26-2005, 08:40 AM
69gtocv 69gtocv is offline
I have the same as woodys on my convertible
