Old 12-15-2013, 07:41 PM
Jeff Hamlin's Avatar
Default '69 Timing Belt Assembly
Not perfect but has been stripped and painted.
Has the typical pulley groove, but no cracks.
Comes with everything shown.
$45 to your door/lower 48.
Cheers
The Following 2 Users Say Thank You to Jeff Hamlin For This Useful Post:
Old 01-11-2014, 12:36 PM
sprint6ohc's Avatar
sprint6ohc sprint6ohc is offline
Jeff, just remembered my cover has three holes , aluminum . If memory serves me, that is for a 66 67. Two hole covers are 69 only?
Old 01-11-2014, 07:03 PM
Cast Aluminum is '66 Only and the 2 bolt is '69 Only.
The other change for '69 is the use of a bolt-on upper rear belt cover, so the front cover now sports ears
The 66-68 uses the front 2 cam house bolts to retain the rear top cover.
I'm 99% sure this is '69 only but have seen a few on some '68's which I do not think is correct.
Old 01-14-2014, 07:11 AM
X2 on the applications Jeff, the only thing I can add is that early 66's also had an aluminum lower timing cover (behind the HB) and that I have seen some early 67's made thru the 1st week of October 66 with the 66 Style Aluminum Timing belt cover.
I agree with your comment on 68's but I have only bought a few 68 Engines over the years, never even owned a 68 Parts car. And they all had what we consider the 67/68 Timing belt covers. But I would believe it was possible that late 68's could have received 69 Cover assemblies. I have learned never to 100% rule things like that out.
Old 03-04-2014, 09:21 AM
$40
Old 03-10-2014, 07:11 PM
SOLD,
THANKS.
