Old 09-28-2023, 03:11 AM
Default 8 lugs
I know that the drums changed in 1963 so the wheels had to change too. Will 1960-1962 trim rings fit the 1963 up wheels? What shade of silver are the early wheels? I believe the wheels and drums that I have are 1963's. The drums are unpainted aluminum color and have left and right threads. The center caps are the 1963-1964 type. The wheels are black but could have been repainted and there was 1 large trim ring. I am planning on installing them on a 1962 and need 2 rear drums. I don't care about correctness I just want 4 matching drums. Am I correct in assuming that 1963 up rear drums will match? Thanks.
Old 09-28-2023, 08:47 AM
Stuart's Avatar
Stuart Stuart is offline
I think this old Smoke Signals article from the 1990s is still the best online reference for the how 8 lugs changed over the years. http://www.teufert.net/pontiac/8lug/8lug.htm
As far as I know, either style trim ring will fit any of the wheels. I'm not sure if the silver color of the early drums has ever been conclusively determined, I personally just bead blasted them and left them bare aluminum - I did file the edges of the fins and then sanded them with 400 grit sandpaper to polish them up. I think the rear drums fit all years, the difference is if they were black or not, along with the length of the fins.
The Following User Says Thank You to Stuart For This Useful Post:
Old 09-28-2023, 03:02 PM
JC61's Avatar
JC61 JC61 is offline
The fins are shorter on the 1960 and 1961 Aluminum wheels.
I believe the pre 1964 drums were bare metal .
All rims early and later will fit all drums as well as center caps and trim rings.
I believe 1963 was the last year of right and left threads.
Old 09-28-2023, 07:28 PM
Anyone know what color the 1962 wheels are?
Old 09-28-2023, 08:09 PM
Stuart's Avatar
The brake drums or the rims? The rims are silver - the link I posted earlier has the color recipe, although I painted mine with Krylon Dull Silver and I think they look pretty accurate.
Old 09-29-2023, 09:35 PM
The car is a "driver" so dull silver is close enough. Thanks.
