#121
Update:
Yukon engineering contacted me today. Said they rarely see a failure like mine and if they do they attribute it to the carrier not having enough bearing preload. Stated that their 33 spline Posi is designed to hold much more power than I’m putting down. Also states that the bearing boss is not thin( even tho it measures thin). Yukon also provides a lifetime warranty for their diffs for an extra 50.00$ and lifetime warranty on gear set for an extra 45.00$....no questions asked, it breaks, they replace it. Talked to Eaton again. They have not seen this type of failure on their diffs. They unequivocally state that their strongest limited slip diff is the TrueTrac without question....... After deliberating, I bought a TrueTrac and new gear set from quick performance. Thanks much for all your input
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
#122
Let us know how it works for you.
#123
I'm interested in seeing how it works, I was thinking about one for my 9".
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#124
Same axles?
#125
yes
#126
Just to say outloud, the 8.5 I built for the 442, if I recall correctly, was about $1900. Only thing I didn't do is weld the tubes, but the welds were checked. This was as I remember because the builder said it was not needed. (no need to go into this here)
So $1900 is roughly only about $600 less than doing a new Moser 12 bolt. You will love the TruTrac. It is hands down the most even application of power of anything I've ever driven. No burps, hiccups, clunks, nothing, just smooth. .
#127
Looks like the bearing inner race had spun on the diff before it broke. What did the bearing look like?
#128
Looks like the case to ear surface was pretty thin.
#129
Like Yukon said, maybe the side load wasn’t enough? Still studying cause and wonder if bearing did not have enough friction fit on boss or whatever reason?..........you would think the bearing would have to fail completely to spin on boss?.....bearing spins on boss and bang it snaps boss clean off..... Could be bearing was spinning for a loooong time before boss broke?.....you would think it would leave signs of heat or bearing destroyed?
#130
#131
Note: when I put this thing together I do remember the diff going in very snug......needing dead blow to seat bearing cups .... without case spreader I’ve always tried to get the diff in as snug as I can
#132
One thing I’ll definitely be doing this time is using permatex sleeve retainer for insurances.........
#133
Everything’s back together.......motive 3.55 gear set and 33 spline Detroit truertrac.....two thumbs up for the Truetrac diff. So far....very nice piece
#134
Any time on the track? How is the hook? 33 spline axles must be pretty beefy.
#135
Looks like the side bearing spun causing the carrier to snap. I'm thinking the bearing failure started this scenario. The way the inner race ate into the carrier, the gears became too far apart. So bearing failure first, then gears/carrier in short order. I did a gear swap on a truck 12 bolt once, the side bearing had spun but had not failed. Owner did not believe me when I told him his carrier was junk.
#136
No track time yet. .....yeah the 33 spline axles are beasts.....probably overkill
#137
