What gas mileage should I expect.
What gas mileage should I expext?
I have built a pontiac 400 1965 Tempest Bored .040 Flat top pistons stock #15 heads Crower 60243 cam factory cast iron exhaust manifolds with dual exhaust. Quik fuel 735 cfm Hot rod carb 2004r over drive 3:73 rear end x .68 over drive = 2.53:1 Timing base 12 degrees with 34 all in at 3000 rpm. Cruises 2300 rpm at 70 mph with about 1200 miles on the engine I took a 500 mile trip to Des Moines Good guys. I averaged about 11 miles per gallon. Does that sound correct? |
I get 18 mpg on pump gas with a hell-of-a-lot more power, a 700r4 and 4.30's. Something in your setup or calculations doesn't seem right.
I should say that my number is an average. At 70 mph I am doing between 2600 and 2800 rpm. Last edited by Chief of the 60's; 07-06-2018 at 11:07 AM. |
Do you run vacuum advance? It will help
I am running vacuum advance 10 degrees on manifold vacuum.
also running a unilite conversion. |
23~2400 RPM (close to 65 MPH) gets 10~12 MPG. 2800 RPM, 75ish MPH gets 16~18 MPG. The engine just ain't happy (running free) lugging at 2300. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
I get about 17 on the highway. Do you have a lock-up convertor or no?
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
No lock up
No. No lock-up convertor either. 31 rear tire though.
OP, is your speedo calibrated correctly? It will make a big difference in your calculation. Mine is right on at 40, 50 and 1/2 mph off at 65 per the local sheriff's radar.
My stock 68 with 2.93, auto, would get 17-18 mpg at around 70-75 mph. (with original Q-jet).
I've heard a lot of people over the years mention 17-18 mpg with anything close to stock and with reasonable gearing. |
Do you know the jetting is correct? (AFR gauge etc)
What intake manifold?
http://www.machdevelopment.com/album...775/527566.htm |
11 MPG? YIKES. My tripower 389 powered 3.36 geared 4 speed GTO gets 14-16 mpg. And my '67 GTO ragtop is built almost identical to your car and gets 21 mpg at a steady 75-80 and has gotten 23 mpg at a steady 65. Mine is a '67 400, bored .030, flat top pistons, #15 heads (1970 455 87cc) , 068 cam, factory manifolds, original Quadrajet, original points distributor, Turbo 400 (no OD), and a 2.56 rear end. My base timing is 8 BTDC with all in 36 at 3500 and about 50 at light cruise 2000 rpm. I've been consistently getting 21 MPG highway with this car for the past 7 years and 10,000 miles. I suspect your fueling system is too rich. My car weighs about 300 pounds more than yours and I am getting double the fuel mileage...all with 50 year old parts.
Jeff |
Quikfuel carb likely doesn't help. Add more vacuum timing. At 2300 RPM, the mechanical advance isn't all-in, so you're running slightly retarded timing. How are engine temps?
Engine runs between 185 and 190 on a 94 degree day
I am not sure what you mean by add more vacuum timing. Does that mean a different vacuum advance?
The reason I questioned this gas mileage is because my 64 GTO 4 speed tri power got 19mpg with 323 rear
But at 2300 RPM, you might have half the mechanical advance, so instead of 22* mechanical, you've got (I'm guessing) 11* mechanical at cruise. So 12* (base) plus 11* (mechanical adv) is 23* total. Add the 10* of vacuum and you're at 33* total at actual cruise RPM of 2300. Now the lower engine RPM may or may not need more timing, but only experimentation will show it. There are 3 ways to increase timing at your cruise RPM: Add more vacuum advance timing, or quicken the mechanical curve by changing the springs, or. Give it a few more degrees of base timing, which will add timing everywhere. If you could add (lets say) 2-5 degrees of timing at cruise, you can see what effect that has on engine performance, octane requirements and fuel consumption. If it isn't any better, go back to your original settings, as too much timing is just as bad as too little. The vacuum advance is the "safest" play to add timing, as it is a load sensing device. As such it adds timing at light load and will reduce timing during heavy throttle. Fine tune the ignition timing and then work on the carb. And I'm serious about the carb too, a Q-jet would give better mileage than most hot rod holley carbs.
The first thing to check is your numbers.
If you have a highway handy with mileage markers, do a 20 mile run and check your odometer against the mileage markers. Rear gear change or tire diameter can greatly effect the accuracy of the odometer. I don't have a 400 A/T to compare, but my highly modified 350 4-speed with 850 Carter does almost double what you posted overall; have not checked highway mileage. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
The speedometer is 1 mile off on hiway mileage signs and GPS. At 70 my speedo says 69
It has an Edelbrock performer intake and quikfuel 735 carb My vacuum advance is not adjustable should I get one that is? Thanks |
