Aftermarket connecting rods: your .02 ?
Im gonna build a 455 for my T/A which will be a corner carver as Ill also be modifying the suspension for the twisty back roads.
What aftermarket connecting rods are good these days ? Is a stock windage tray sufficient or should I look into oiling mods ?
Two 1975 455 Grandvilles & '79 455 Trans Am 69 Camaro SS 396/375 (owned since 88) 22 Toyota Sequoia V8 23 Lexus LS500 awd 95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
I currently have Eagle rods in my 474. If using Eagles I would do the bolt upgrade. For my 535 build in progress I am considering Callies rods.
As for the stock. Windage tray has a tenancy to develop cracks and fall apart. |
Scat h-beams here, 10 years boosted with no problems.
Cliff has posted that most all the Chinese H-beams he's seen have checked out good. The RPM H-beams are usually about $65-$75 cheaper than Eagle Pontiac length rods.
http://www.racingpartsmaximum.com/sa...elhbeam-2.html https://www.amazon.com/Eagle-Special.../dp/B000CN7ULM |
Molnar is getting really high marks.I looked at one of his cranks and a set of his Hbeams last weekend.I have Curillo in one engine and Scats I another.The V I'm building will have Scats or Molnars.Tom
Brad, one name: Crower.
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
Callies alas uses L19 rod bolts which are stronger under ideal conditions but potentially way weaker owing to susceptibility to moisture. A rep at Callies would inform me in a 2018 phone call that Callies uses the L19 bolts for the past few years, even though many internet vendor listings for Callies will continue to state that they still use ARP2000 bolts.
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads 1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455". What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere? |
The Canton road race oil pan and pick up for corner carving.
73 T/A 455, 4speed |
I have eagle rods and canton road race pan, 5 years of boost, never a rod problem, I did upgrade the bolts.
I have SCAT in one motor Eagle in another motor.
Canton has better baffling than the Moroso for cornering. If you have an auto tranny and really sticky tires you might need to extend the vent tube. My TA used to sloch tranny fluid out until I did "fogging mosquitoes" when it hit the exhaust.
Been using Molnar rods and cranks last 5 engines
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
I used Eagle rods in my current engine build. They are very nice rods. Machine work was excellent. Sleeves in the threaded holes on the journal end to locate the cap. Done very nice. Screwing down the ARP bolts felt like turning a micrometer....the machined threads felt like precision work.
I didnt upgrade the ARP bolts since I am sticking with stock power levels. For me, this is the first time using forged rods in a Pontiac engine so I can only compare this set to the prepared cast rods that I used to use in the 80s and early 90s. Back then I couldn't afford forged rods. Glad to see there are so many reasonable choices available these days. Sounds like a fun build. Sent from my SM-G930V using Tapatalk |
Eagle Rods can't go wrong ...
If your corner carver will have a need to do sustaned rpms above 4000 and your 455 is still based on a 3.250" main Crank then a oil cooler and aroad race type baffled oil pan better be on your list of needed things because it does not matter how good your Rods or your main caps are when the Bearings go south first due to overheated oil and or oil starvation!
There is a guy on here that road races a first gen bird. I would get with him. Can't remember his screen name
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
BME anymore?
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. The mind, once stretched by a new idea, never returns to its original dimensions. |
Callies is one of the best.
My RAIV motor does have Crower billets but when I built it there were few choices. I want to think they were kind of heavy also 900gm range.
Thread Tools | |
Display Modes | |
