Eagles in the 482. Still deciding what to put in the 535. Oliver’s in my 385 SBC.
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
Eagles are cheaper; think theyll do for 5500 rpms max. I was gonna do Edelbrock heads but Ill probably use some 6X 400 station wagon heads like I have on the GV.
Two 1975 455 Grandvilles & '79 455 Trans Am 69 Camaro SS 396/375 (owned since 88) 22 Toyota Sequoia V8 23 Lexus LS500 awd 95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
I bought the Molnar Power Adder 6.8 billet rods. But for this application the standard rod is more than enough. Used on 1200HP engines. I bought the Power Adders simply because they can take far more power than I will ever put out and still, are lighter than the Callies rod. 1600$ vs 630$. It cost less for the Molnar rods as the money it would take me to rebuild my Crower billets to take 7500RPM. For more RPM than that just the bolts are 700$ then the rebuild. Bought the Molnars and still have the Crowers for less. |
Particularly if such parts have been cryoed?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads 1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455". What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere? |
Brother I've run RPM, Eagle and Scat in Pontiac stuff. I've not run a stroke over 4.25 with those rods. I've not had any problems with any of them. I've run 4.25" stroke engines with these rods to 6500 rpm with no problem. I've run 3.75" stroke engines with the RPM rods to 7300 rpm with no problems. I think all of these rods run higher rpm without issue. The problem is the bolt strength on the cap and not the beam. Upgrade the bolts and you'll be good.
I am not the guy to ask. Tom Molnar will talk to potential customers about rods and cranks.
If you are road racing, canyon carving, all posted will hold up. I would pick the lightest of the group. the eagles with a arp 2000 bolt are good to 1500 h.p. per there web site.
I would think you would want the lightest rotating mass possible so pulling from corners the rpm's come up faster. Just my .02 I don't r/r but have a friend who does. |
I've run Eagle rods wirg upgraded rod bolts to 8200rpm with a 4.250 stroke, moved to Callies Ultra rod and spun the engine to 8800rpm without issue
Callies ultra in my 535...
3500lb 10.5" tire. 5.34@134.4 with a poor 60' |
Callies- looks great but what about the rod bolts- L19?
https://www.yellowbullet.com/forum/s...d.php?t=207140
Oliver 6.8 rods. 817 gr.
But I have Eagle in my 433 stock block build.
www.hobracing.com |
and the Oliver C6700BBMX8 Rod?
Callies Ultra rods are made with 4330 and Olivers are 4340. You cant go wrong with either one.
I went Eagle H-Beam CRS6625P3D in my 455 build winter 2013 and push the car in street applications. No problems but added a rev limiter for the few over revs done accidentally (no engine problems though). I also used Icon IC888.030 Flat Top Forged Piston Set to further lighten things.
Good deal, good luck!
Thread Tools | |
Display Modes | |
