Old 06-18-2021, 09:44 PM
rcush's Avatar
rcush rcush is offline
Default Good exhaust kit
I am going to put headers and replace exhaust on my 67, what exhaust kit do you recommend? I plan on Doug's headers then want 3" exhaust. Any recommendations?
Thanks!
Sent from my LM-Q710(FGN) using Tapatalk
Old 06-18-2021, 10:08 PM
fyrffytr1's Avatar
I have the Pypes 2.5" system on my 67 and have not had any problems with it.
Old 06-18-2021, 10:10 PM
rcush's Avatar
That is an option, would like to do 3" if possible, Thanks!
Old 07-12-2021, 11:27 PM
todden8 todden8 is offline
Not me but my brother has Dougs Headers also. He ended up getting the 3" Magnaflow 15898 exhaust kit from 4wheelonline. The sound is really nice. imho
Old 07-13-2021, 10:46 AM
76TA462 76TA462 is offline
Used Magnaflow Welded for years with 2.5 Pypes X-Pipe, and always liked the sound, fit, etc. The Pypes needed some modification for fit but not a drama. Used Hedman 4-tube and Doug's (very surprisingly the Hedmans fit better. I had to massage the heck out of the Dougs on the passenger side and ended up going back to Hedman). Currently using Borla ProXS 40352 and Vibrant resonators pn 1793 behind Hedman Shorties 4-tube pn 26164, still with same Pypes x-Over. Very happy with the current set-up as well. Did the change for lowering clearance. I was concerned about performance loss going to the shorties but clearance was more important. I don’t feel any seat of the pants difference, but I don’t to the 8,000 rpm thing lol. The sound is excellent but different from the Magnaflow. 1976 Trans Am.
Old 07-13-2021, 02:39 PM
rcush's Avatar
Awesome, thanks for the input, bet they sound awesome!
Old 07-13-2021, 04:50 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Pipes 3" gets a lot of good reviews from people I know. I have a RARE system which I like but it took a lot of cutting.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 07-13-2021, 06:47 PM
rcush's Avatar
I think I will go with Pypes 3", got both stock exhaust manifolds loose but unsure how to remove car, do I need to loosen engine mounts and lift engine?
Old 07-13-2021, 11:06 PM
1965gp 1965gp is offline
I don’t think you should have to lift the engine? Maybe try different angles?
Old 07-13-2021, 11:11 PM
rcush's Avatar
Will try again tomorrow, hopefully I can find the right angle, Thanks!
Old 07-14-2021, 04:37 PM
gtospieg gtospieg is offline
rcush...you should check out the episode of "engine masters" where they tested different size exhaust...2.5 and 3. The end result was unless you're making more than say 600hp the 2.5 isn't hurting anything, and it fits easier and it's less expensive.
