Old 03-14-2024, 08:41 PM
Can only tell you what not to do with a Uhaul car haul trailer.
Don't haul a B350 1Ton Dodge extended Van on one of them unless you can stay under 45mph for the length of your hauling trip.
Could only load the Van on the trailer forwards.
So majority of weight was on the tongue.
Anytime my Dad approached 45+ it would go into death wobble fishtails.
After the 2nd time I protested that he let me drive.
After the 3rd time I protested to let me out so I could walk the other 90 miles home.
Don't know how we didn't crash on that last one.
Then finally he kept it at 42mph the rest of the way home.
If the Van could have fit on the trailer backwards - it probably would have been even worse that way.
Towed a 66 GTO convertible on a Uhaul trailer with a Jeep Grand Cherokee V8 and it did fine.
Even though it was above its towing capacity a little.
Just stayed at 55mph
Old 03-14-2024, 08:42 PM
jamesq's Avatar
jamesq jamesq is offline
I pulled a 65 Lemans convertible from Indiana to S MIssissippi (750 mi) a few years ago on a Uhaul trailer. I used a small Uhaul van as the tow vehicle.
I had a trailer tire blow out just south of Huntsville AL. It took about four hours total for Uhaul to send someone out and replace the tire.
I have used the Uhaul trailers about half dozen times, they are very easy to load and unload and that was my only time to have any issue.
FWIW
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
The Following User Says Thank You to jamesq For This Useful Post:
Old 03-14-2024, 08:47 PM
When I used the Jeep GC , I had to use my drop hitch upside down as a lift hitch.
Those trailers are heavy just by them self.
Over 2000 lbs
Old 03-14-2024, 08:58 PM
mrennie's Avatar
mrennie mrennie is offline
My only contribution is related to tongue weight. Typical recommendation is 10-12% tongue weight. In my experience 12-14% is a safe bet. Too light and trailers can sway.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
The Following User Says Thank You to mrennie For This Useful Post:
Old 03-15-2024, 02:55 PM
vertigto's Avatar
vertigto vertigto is offline
Question for those that have used axle straps for tie down, rather than the web-style over the wheel straps? Did you run them through the wheels? Around the engine cradle and axle tubes?
Old 03-15-2024, 06:20 PM
dataway's Avatar
dataway dataway is offline
Along the same line .... does the U-haul car trailer come with adequate equipment to secure the car to the trailer?
Old 03-15-2024, 09:19 PM
OG68 OG68 is offline
Front tire straps and safety chain
ID:	630443   Click image for larger version
2007 Cadillac SRX
