Old 09-08-2022, 09:18 AM
Jhankins Jhankins is offline
Default 77 GP 400ci EGR delete or replace valve
I'm trying to decide if it's easier to just delete the EGR or replace it? My egr back pressure valve is damaged and I'm not sure about the condition of the EGR valve itself. If I just install blocking plates will it cause any other performance issues?
Old 09-08-2022, 10:08 AM
78w72 78w72 is offline
i blocked the EGR on my 78 400, no noticeable issue in performance or how it idles & runs. did it on an 81 turbo as well. some say it can actually increase performance by eliminating the hot exhaust gas in the combustion.
on my 78 i used a block off plate but kept the EGR in place to hold the block off plate & it still looks stock.
Old 09-08-2022, 10:43 AM
Sirrotica's Avatar
I used to have a customer that owned a 77 S/E T/A 6.6 4 speed car, even when it was new, the EGR system was having problems, and wasn't operating properly. One attempt to get it repaired under warranty, and it still didn't get squared around, so per the customers request we deleted it. I believe it was the back pressure valve that the dealer replaced.
I remember that the parts were hard to get at that time, and as I remember, expensive. One of the brazed joints cracked at under 10,000 miles, just not a very reliable system.
It ended up with an 068 cam in it, headers, H tube balance pipe, recurved distributor, re-jetted Q Jet, and true dual exhaust with dual cats, and a Holley Street Dominator intake manifold, it ran very well with the modifications to a smog era engine.....
I borrowed the car from him once to race in the local SCCA chapter autocross, and won my class with it. If memory serves, I gave him the trophy that I won.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-08-2022, 11:00 AM
Ok thanks for the info!
Old 09-08-2022, 11:42 AM
77 Canamman's Avatar
I left everything visibly intact on my '77 T/A with the W72 400. All that was done to disable the EGR is to place a bee bee in the vacuum hose to the valve. That way it appears hooked up and functioning, but no exhaust gas to enter the intake mixture.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 09-08-2022, 09:01 PM
That's a good idea to plug the vacuum hose.
Old 09-11-2022, 10:09 AM
Do they even make the backpressure assembly anymore?
Old 09-11-2022, 05:17 PM
No they don't make it anymore! It's ebay, repair or delete it!
Old 09-12-2022, 10:59 PM
If you want to get rid of the operation but keep the look do like we used to do when they were new. Put a ball bearing in the vacuum hose and reinstall the hose. The only problem you might have on a completely stock engine is is a ping at low speed and a heavy load. Use better gas. As for getting more power that's bull. The valve is NOT open at wide open throttle. There is no vacuum to open it.
Old 09-12-2022, 11:14 PM
I was actually thinking of just leaving it the way it is! I don't believe there is a vacuum leak. The pipe on the back pressure valve has come off so I'm thinking it won't open the EGR valve possibly leaving it stuck closed? I have to drive the car and see if I have any issues!
Old 09-13-2022, 07:29 PM
jerry455 jerry455 is offline
I would leave it all there and make it nonfunctional. I wish I had all of the original emissions stuff for my 1976 Firebird. I am going to make my engine look as stock as possible while still having headers, Edelbrock heads and intake. I like a more sleeper appearance car. If I remember correctly, when we used to remove EGR, back in the day, we had to adjust the timing and richen the carburetor.
The Following User Says Thank You to jerry455 For This Useful Post:
Old 09-13-2022, 07:55 PM
Yeah sounds like a good plan!
Old 09-15-2022, 08:52 AM
Lightbulb
Maybe bull in the regards of WOT power, but certainly more power at part throttle and tip in.
The Following User Says Thank You to 77 Canamman For This Useful Post:
